Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
my 90 sport 2wd 4x4 needs some clearance
I dont remember if a posted anything about my lil truck when i first got it, but I'm for the most part done with my swap. 1990 toyo pickup sport 2wd. Doner 1989 toyo pickup 4x4. Swaped my body and motor to the 89 4x4. swaped in a good 5speed over last weekend b/c the one i had turned up to be bad. I put a set on 31/10.5/15 mudder tires on and it just barly rubs the front air dam. Any ideas on how to make the truck clear the tires with out dumping $1,000 for a lift? I dont know much about useing the bars to lift, i know i have a set of blocks laying around... any idea are welcome.
| Sponsored Links |
#2 (permalink) |
If it's just a bit of rub at full turn, I wouldn't worry about it.
The cheapest way to fix the rubbing is going to be wheel spacers- Marlin's got some for $79 a pair. Or you could go with a different backspace on your rims. Search around, tire size questions have been covered many, many times here and other boards. ![]() |
#3 (permalink) |
well see thats just it. it wont rub at full turn either way. it's just rubs on that air peice that mounted to the bumber on the front. not to be a pain. i just dont know how to adjust the torsion bars to make it somewhat higher in the front. it looks like to me if you mess with the bolt it could only lower it. it's stock hight.
__________________
90 sport 4x4 |
#4 (permalink) |
i would say the best way is to just get a small body lift and/or trim the front air dam
__________________
2000 4Runner Limited V6 Auto... 2wd =[[[ Sony GT510 head unit, Kenwood 1700 watt max mono amp, Two 12 inch Polk Subs in ported box, 3 farad capacitor, neons in front footwells Foglights on bottom of rear bumper Optima Yellowtop, Kc daylighters on front bumper Vortex muffler and Trueflow airfilter |
#5 (permalink) |
the torsion bar bolts will lift when you tighten and drop when you loosen them.....look at the bolts, that should be pretty clear.
__________________
-Andrew 94 4Runner 3.0 Auto. I got mods |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 03 4runner 2wd sport, Bilstein shocks upgrade | dmar | 03+ 4Runner/GX470, & 05+ Tacomas | 1 | 01-03-2008 01:11 PM |
| 99 Sport Ed. 4x4 5spd Leather | MTwEeZi | Hot Deals/Free Stuff | 3 | 05-23-2007 04:02 PM |
| 02 Sport 4x4... n00b.. | teamblend | 4Runners-3rd gen | 0 | 10-17-2005 08:24 PM |
| Ground clearance - Tacoma 4X4 vs 4Runner | dcampen | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 05-13-2004 01:38 PM |
| '03 Sport 4x4 with AP spotted | Sac State | 95.5-2004 Tacomas & 96-2002 4Runners | 21 | 07-19-2003 02:17 PM |
