Marlin 5" rear leafs not flexing - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-17-2009, 10:43 AM   #1 (permalink)
Hey all.
I've installed a Marlin 5" lift (with the Betts springs) on my 79' PU. The front flexes great but the rear leafs are far too stiff and pretty much don't flex at all. I don't carry anything in my bed but a spare and hi-lift so there is no weight back there. I tried breaking them in on a few trips with my ATV back there. They flexed great then, but as soon as I ran it empty again...no flex. I've put it on its side twice now since the rear is so stiff and it gets really tippy going downhill over off-camber stuff.
I see the spring rate is 220 on these. Would taking the bottom leaf out the pack lower the spring rate? I'm thinking I may need closer to 175 or so. Any tips on making these perform? My only other thought is to buy some custom Alcans or Deavers...but thats another $400 I don't really want to spend. I'd rather get the ones I have to work, but right now they just won't compress.
Thanks ( I've posted this on the Marlin forum too)
__________________
79' PU, 22RE Swap, Marlin 5" lift, 5.29 Locked F&R, Marlin High Steer, Longfield 30 splines, Marlin Ultimate 2.28/4.7 and Twin Stick, Marlin 5spd, Marlin Clutch, 37" KM2's and 3" rear/1.5" front spacers, Trail Gear T-case skid, Marlin long-travel front driveline, Addicted Offroad winch bumper with 8500 Superwinch.
mjos is offline
Old 09-17-2009, 11:11 AM   #2 (permalink)
4Crawler's Avatar
Usually you want to remove the second leaf from the bottom to soften up the spring pack. Best to contact Marlin's support forum and ask about that.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-17-2009, 11:35 AM   #3 (permalink)
Roger, the second one from the bottom is held in with the big rivet and spring clamp. I agree that this leaf would make the biggest change but I am unsure how to get it out of there.
__________________
mjos is offline
Old 09-17-2009, 11:43 AM   #4 (permalink)
4Crawler's Avatar
That is why it would be best to ask on Marlin's forum for specifics.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-17-2009, 11:44 AM   #5 (permalink)
algranger's Avatar
Cut the clamp and grind the rivet down (or drill it out)
Then just make a new clamp.... if you are set up to weld
Those springs are designed for a little more weight
They also need to be broken in... theyre stiff to start, take some trips with some concrete bags or something just to give the springs a little workout
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 09-17-2009, 01:05 PM   #6 (permalink)
I found a good article on getting the rivet out and replacing it.
http://www.off-road.com/trucks4x4/ar....jsp?id=186291
__________________
mjos is offline
Old 09-17-2009, 02:48 PM   #7 (permalink)
tc
tc's Avatar
What's your shackle angle like? What shocks are you running - and if gas charged, what psi are they at?
While I don't doubt that the rear is too stiff, the front could easily be too soft too and you're not getting any leverage to compress the back.
Lastly, I don't want to sound like an ass - but you don't have a one-size-fits-all truck, what made you think a one-size-fits-all spring would work for you? The less "stock" your rig, the more you NEED custom springs...
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is online now
Old 09-20-2009, 07:26 AM   #8 (permalink)
I took the 3rd from the bottom leaf out. Man what a difference. I flexed it out on the lift and the rear tire could now be lifted over 3ft and the fronts still stayed on the ground. Can't wait to try it out.
__________________
mjos is offline
Old 09-20-2009, 07:36 AM   #9 (permalink)
yoder519's Avatar
pics!!!!!!
__________________
Sold&Missed
95 Yota pu 22RE/33x12.50 Maxxis Buckshot Mudders/TG Sliders/4Crawler 2in BL//TG Diff Breather/Herculined Floorboard/Magnaflow Hi-Flow Cat/2.25" Exhaust/Glasspack/Procomp black steelies/Procomp shocks/Superlift 2" AALs/4 Crawler 1.5" BJers
1998 Dodge Cummins 24V 4x4 5spd/Quad Arenaline/4in Exhaust/6in Tip/AFE Intake
yoder519 is offline
Old 10-07-2009, 09:28 AM   #10 (permalink)
Some pics
Here are some shots before I trimmed the front and rear fenders. Since trimming them, I get about 2 more inches of tire stuff and more downtravel on the other side.
It's like a different truck on the trail now. No more carrying tires in the rear and getting all tippy anymore. I just need to adjust my rear pinion angle a bit now and I'll be all set.
marlin-5-rear-leafs-not-flexing-image050-800x600-.jpg   marlin-5-rear-leafs-not-flexing-image051-800x600-.jpg
__________________
mjos is offline
Old 10-08-2009, 03:08 PM   #11 (permalink)
Volcom's Avatar
Use to the lift to pick up the front tire. In your pics, you're flexing your front suspension more than the rear.
__________________
1984 Toyota 4Runner
EFI swap
TG 4" springs
Marlin Crawler Dual Ultimate Crawler
39.5" Iroks
Addicted Off Road 8 point cage
Addicted Off Road front bumper
Addicted Off Road
My 4 wheel drive club
http://www.rockfrogs.org
Quote:
Originally Posted by cubuff4runner
Let them puppies BREATHE!
Volcom is offline
Old 10-09-2009, 03:34 PM   #12 (permalink)
SC4Runner's Avatar
Thats a beautiful rig man
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe.
1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe.
SC4Runner is offline
Old 10-10-2009, 07:57 PM   #13 (permalink)
Fvckin badass '79 man
Yeah lets see the front up on the lift
__________________
Tyler
1992 White Runner 3VZ/A340
5VZ/R150(in progress)|Inchworm 23spl|MC XD 23spl 4.7's|D60/14B waiting to go in after winter
It's A Jaap Thing
A New High is offline
Tags
1985, 4runner, 5, driveshaft, flexing, front, lift, lifted, long, marlin, marlins, offroad, rear, toyota, travel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
