| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Low profile bumpstops
__________________
95 SR5 4x4 4runner Sony Xploid cd player(not sure which one) Rockford fosgate 900 watt 2 channel amp, 2 600 watt kenwood 10 inch subs. Some cheap cb from walmart Surco safari rack with 2 KC Daylighters 15x8 tech 1 rock crawlers Spintech exaust external fuse box mod. Airbox MOD. K@N Air Filter. ISR MOD Downey HD's |
#2 (permalink) |
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#3 (permalink) |
They are universal
#4 (permalink) |
FYI: Low profile bumpstops should increase the travel of IFS, Unfortunently this will increase the angles of the Drive Axles during flex thus making it easier for your CVs to break
__________________
#5 (permalink) |
with the cv joints possibly breaking, is there any way to add low profile bump stops and prevent the cv's from breaking? just curious
#6 (permalink) | |
Quote:
__________________
Milton 01 Tacoma access cab 4x4 TRD TC Long travel, Supercharged 04 Tacoma Doublecab 4x4 TRD hoes all around! |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) | |
Quote:
I broke 3 c.v.s in less than 5 months with a welded front end. Just be kind to the axles!
#9 (permalink) |
well, i guess if you add them (which i think im gonna do), just dont go WOT in the mud or rocks, and just pick good lines. i'm just one of the many that a SAS will not look good with my bank account, and if i can squeeze even a little extra travel out of the ifs, i will. just tread lightly
#10 (permalink) |
What makes more of a difference in front end articulation--low profile bumpstops or sway bar disconnects? Or must you do both for any real difference?
__________________
1995 4Runner---SAS with goodies |
#11 (permalink) | |
Quote:
__________________
#12 (permalink) | |
Quote:
__________________
http://www.angelfire.com/ca6/954runner GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1. ..."But officer, that was not an illegal turn, it was just an undocumented turn." |
#13 (permalink) | |
Quote:
Your CV's will thank you
__________________
#14 (permalink) |
That was one of my earlier mods--
http://community.webshots.com/photo/...04772299nfzlGR So I need to do both, or does it really make a difference?
__________________
1995 4Runner---SAS with goodies Last edited by Marc P; 12-20-2003 at 08:07 PM. |
#15 (permalink) |
i didnt even bother with my compression bumpstops because when generally flexing, they dont even touch. only when i hit a bump with speed do they hit.
for the extension bumpstops, i just used a hacksaw and cut the rubber down to the height i wanted. |
#16 (permalink) |
so is there anything wrong with cutting all of the existing bumpstops down? or is this impossible for some reason?
__________________
1994 White 4Runner 5 Speed SR5 4X4 ~121,000 Miles Land Cruiser Coils ~ 1.5" Ball Joint Spacers ~ Buschwaker Fender Flares ~ Cobra 19 DX II ~ Asin Manual Locking Hubs ~ Alpine MP3 HU ~ 2 10" MTX Subs ~ Pioneer 4" Speakers ~ Husky Floor Liners ~ Indiglow Gauges ~ Clear Corners ~ 15"x8" Rock Crawler Wheels ~ 33x12.5 BFG AT's ~ Diff Breathers ~ Yakima Crossbars ~ Sylvania Silver Stars http://community.webshots.com/user/kevywevy84 |
#17 (permalink) |
The rubber of the factory stops are softer than the urethane of the ES lo-pro units. If you take material away, they may not do anything. Total cost of the parts for the ES Lo-Pro ones was like $21.
__________________
#18 (permalink) |
You can definitely cut down the stock bumpstops a little more than halfway before you get too close to the bolt head, I did. The shorter you make them the stiffer they'll get as there's less material to compress. I'd only cut down the 2 extension stops though, the 4 compression stops on my truck never got used except under high-speed conditions and having that extra cushion was nice because it stopped any harsh impact when the suspension bottomed out.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!" |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Low Profile Polyurethane Bumpstops | Robinhood150 | Off Road Enhancements | 0 | 01-07-2006 07:12 PM |
| Low profile bumpstops. Both or only compression? | Blizzard | Offroad Tech | 4 | 06-22-2005 12:02 PM |
| Got Low Profile Upper Bumpstops! | 914runner | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 06-10-2004 11:29 AM |
| Where can I get some low profile bumpstops? | '94Runner4WD | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 05-12-2004 08:39 PM |
