Are lockers swappable
Old 01-07-2016, 08:53 PM
Msukefo's Avatar
Hi just a quick question will probably be answered pretty quickly I recently got my first Toyota it's an 82 and it has a spool in the rear the guy said. It's definitely locked in the rear because it chirps on pavement and the tires are shredded. If there is a spool in there can I switch it out with the front one so the front has the locker and will only be locked in 4wd or are they different? Thanks in advance.
Old 01-08-2016, 02:54 AM
arlindsay1992's Avatar
The front and rear diffs can be swapped no problem on '82 axles. Just be careful when you're wheeling because a locked front end is tough on your birfields.
Old 01-08-2016, 05:45 AM
MudHippy's Avatar
I've met a few folks that swear by having a spool in the front. Personally, I found it atrocious. I like to be able to steer precisely.
Yotahuntingrig93
11-01-2015 10:11 AM
83
11
10-20-2015 07:22 PM
robm
10-20-2015 05:32 AM
Jonny246
10-16-2015 02:50 AM
edgar62902
9
10-15-2015 11:30 AM
Quick Reply: Are lockers swappable
