Thread Tools | Search this Thread | Display Modes |
#76 (permalink) | |
Quote:
I had a '94 Mazda Navajo 4wd (same as a same year 2 door Explorer) as a daily driver for many years, first with a rear Lock Right locker, then with front and rear No Slip lockers (the No Slip is smoother and quieter than the Aussie). I had the Lock Right for about 37,000 miles until it wore out, and then had the rear No Slip for about 80,000 miles until I totalled the vehicle. In the meantime, I took 2 trips from Florida to Washington State and back, 4 to Kentucky and back while towing my motorcycle on a trailer, and a few other long trips. I managed just fine. By the way, in the quote that you quoted, it's not locking that makes the tires squeal. It's the fact that, while the vehicle is turning right or left, only the inside tire is accelerating or decelerating the vehicle. Since only the inside tire is moving the vehicle, and since this tire has less weight because the vehicle leans toward the outside of the turn, the tire squeals easily. When this happens, the inside tire is rotating the same speed as the ring gear, while the outside tire is rotating faster than the ring gear. This is also why the handling changes when you install a rear locker. When the vehicle accelerates, the inside rear tire tries to push the vehicle in a straight line. When the vehicle decelerates due to the throttle being released, the inside rear tire tries to make the vehicle pull in the direction the vehicle is turning. The key is, when you are turning, keep steady throttle and don't change speed. Or if you have a manual transmission, push in the clutch. If you have an automatic transmission, the torque converter will absorb some of the shock load created by a locker, and the action of a locker won't be as jerky.
__________________
'06 Tacoma TRD 4wd 4 door short bed, rear locker mod (can use in high range and 2wd now), Skyjacker 3" lift struts with new rear springs and shocks, 285/75-16 BFG All Terrains, more to come. '08 Yamaha FJR1300 with ABS and power adjustable windshield. '06 Yamaha Wolverine 450 sport/4wd ATV '07 Kawasaki Brute Force 750 ATV |
| Sponsored Links |
#77 (permalink) |
__________________
JASON 1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny 31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR |
#78 (permalink) |
His explaination of how a locker works isn't totally accurate. A locker equalizes wheel speed, not "power", which should be called torque.
He was correct in stating that a limited slip sends (transfers) torque to wheel with the most traction. However, a locker does the same thing (although the total amount a limited slip transfers is limited by clutch friction). So he somewhat contradicted himself, because both increase motive force by transfering torque to the wheel with traction.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Toyota FAQ | Silver_Truck | Newbie Tech Section | 25 | 06-09-2008 01:00 PM |
