lock right lockers? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-01-2003, 08:23 AM   #1 (permalink)
doink's Avatar
Send a message via AIM to doink
lock right lockers?
what are your feelings on these? im thinking about getting one, but not sure if its worth it. its either this, or saving up the cash for arb air locker and compressor. any help would be grand
doink is offline
Old 08-01-2003, 08:32 AM   #2 (permalink)
seafarinman's Avatar
Send a message via AIM to seafarinman Send a message via Yahoo to seafarinman
I got one. $217.00 out the door. It was too easy to install. The best low budget mod I have ever done. Quirks are easy to deal with, and it always works whether I need it to or not. What more can you ask for? Seriously, if you are going to regear, then get a Detroit. If not, then a Lock-Right. I don't know about use up front as I only have one in the rear.
__________________
DEPLOYED Again!
1994 SAS 2RZ/R151F=244:1!
1988 Toyota 4Runner SR5
seafarinman is offline
Old 08-01-2003, 08:39 AM   #3 (permalink)
doink's Avatar
yeah, thanks. i wasj ust wondering about putting one in the rear. also, whats the difference btwn this unit and the no slip traction system offered by powertrax as well?
doink is offline
Old 08-01-2003, 08:44 AM   #4 (permalink)
HBoss's Avatar
What exactly is the lock-right? LSD? Selectable locker? Permanent locker? other?
__________________
1997 4Runner Ltd. Bilstein shocks, rear E-locker & riding on 32s.
Mods Pics
Tech articles, write-ups & more are available on my website.
http://www.hboss.net/4runner
HBoss is offline
Old 08-01-2003, 08:48 AM   #5 (permalink)
shazaam's Avatar
Send a message via MSN to shazaam
You might want to hold up .. I'm trying to work out a group buy on a detroit locker .. it might be a little more then the lock right .. but from I've read the detroit locker is quality, and has very little problems.
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards.
<-- the artist formerly known as sdastg1
shazaam is offline
Old 08-01-2003, 02:09 PM   #6 (permalink)
NCSU-4runner's Avatar
Send a message via AIM to NCSU-4runner
ive been thinking of getting the lock-rite. i think i found it for like 180 somethin plus shippin on the internet.
__________________
Jeremy,
94 4Runner Turbo
Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap
My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum
One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first.
NCSU-4runner is offline
Old 08-01-2003, 02:26 PM   #7 (permalink)
Send a message via AIM to statelax3
i am running a lockrite in the rear of mine, worth the money, very cheap, mines seems to be very quiet, no loud poping as i had expected, just tire chirp around corners but hell you gte used to it after a while. ohh and ths install is so easy a monkey did mine
__________________
tube chassis, 22re, w56, duals with 4.7's, 60's, 42 tsl's, hs9k
statelax3 is offline
Old 08-01-2003, 02:35 PM   #8 (permalink)
I just Installed a Lock-Right a few weeks ago and here are some observations that I have.
INSTALL . EASY to install. nothing to it
Operation. It is a full time locker. It disengages when you turn by allowing 1 wheel to spin FASTER then the other, meaning the slow wheel get the engine power. This is kinda neat it sounds like a big craftsman wrench because that is how it works. when 1 tire needs to go faster during a turn it applies pressure to the assembly and it disengages and ratchets on the axle. However this dosent always work so nicely and it can get kinda jerky and jumpy. Especially when you make hard u-turns while applying power. I just use the clutch and glide through the tight turns now. Also beause it does this it will chew up your rear tires more then normal.
OFF road. WOW it makes it so much easier. I don't worry about my tires hanging off a rock or in a trech anymore. It is just great.
And for $200 it is the best off road upgrade that I bought. and chap too
__________________
1990 Yota 4x4
Reg cab V6
4" superlift
33" Procomp MT's
Rear Lock-Right
denver4x4 is offline
Old 08-01-2003, 04:41 PM   #9 (permalink)
flecker's Avatar
Location: White Mountains, Arizona (Yes it does snow in AZ)
Thumbs up I like mine !
It's a quick install for the do it yourselfer, Albeit crucial to get the backlash right(a dial gauge helps here). One thing to consider would be that it uses the "stock" carrier. This weakens the setup a bit, if you intend on doing hard-core crawling a solid Detroit might suit your needs better. Don't get me wrong... I trust mine to get me out of a hard spot (or into one) and keep on groovin' and the added traction is waaaaaay better! If you live near snow country you'll have to learn to "drive again" with it! Just my .02 cents
flecker is offline
Old 08-24-2004, 03:31 PM   #10 (permalink)
outdoorfever's Avatar
Send a message via AIM to outdoorfever
What tools are needed for install guys?
__________________
-Kyle
Forasmuch then as Christ hath suffered for us in the flesh, arm yourselves likewise with the same mind: for he that hath suffered in the flesh hath ceased from sin; That he no longer should live the rest of his time in the flesh to the lusts of men, but to the will of God.
GOD IS A CONSUMING FIRE!!
outdoorfever is offline
Old 08-24-2004, 11:35 PM   #11 (permalink)
SWORDFISH92's Avatar
Quote:
I just put mine in today in the parking lot of my buddy's apartment complex. Mines an automatic and I can hardly notice it, no joke. I bought mine used from a guy on 4x4wire for $100 shipped. Best money i've spent. I have seen some online for $189 for a v6 new.
We used basic handtools, 2 2x4's. Floor jack, jackstands, set of open end wrenches, set of sockets up to 24mm. Hammer, punch, rubber mallet. whiteout to mark things inside the 3rd. and about 2.5 quarts of fluid if its a v6. I'm sure i forgot a few things.
at least in my experience, if youve never torn apart a third before have someone there who has!
__________________
1992 SR5 V6 Auto 4runner
Modifications: ARB Bull Bar, Cobra 19 DX III, 120 Watt PA System, Firestick II, Husky Liners, Maglite Install, Fire Extinguisher Install, Pioneer Deck, Kenwood Front and Pioneer Rear Speakers, Tacoma whip antenna, Hella 1000FF's, K&N Filter, Aisin Hubs, 4.88's, Rear Lockrite, F/R Diff Breathers, 1.5 Ball Joint Spacers, All-Pro Coils, Downey Spacers, Doetsch Tech 8336's, 1" BL from Roger Brown, 32 x 11.50 BFG KM's
SWORDFISH92 is offline
Old 08-25-2004, 01:09 PM   #12 (permalink)
Quote:
What do you mean?
Scary Mc is offline
Old 08-25-2004, 01:30 PM   #13 (permalink)
Has anybody checked these out? Cost, application.....
http://www.tractech.com/Products.htm
Detroit Electrac.
Seems like the best of both worlds posi all the time 100% lockup with a push of the button.
Buki is offline
Old 08-25-2004, 02:41 PM   #14 (permalink)
Mad Chemist's Avatar
I don't think they make one for Toys yet, could be wrong though.
I think MNBOY has detroits or lockrites in both the front and rear, has a hell of a time steering with the front locked...
__________________
-David
'98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops
'73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top.
TLCA#14428
Mad Chemist is offline
Old 08-25-2004, 03:06 PM   #15 (permalink)
4x4Lamm's Avatar
Go for it, at least out back.
The pros outweigh the cons.
Lamm
__________________
-1992 4Runner SR5, Destroyed by fire. Lots of mods. I will miss it.
-1995 4Runner SR5 Limited, Also known as the money pit. Becoming a trail rig now.
-2004 Tacoma SR5 TRD, My new daily driver. I love this truck!
4x4Lamm is offline
Old 08-25-2004, 03:10 PM   #16 (permalink)
EWAYota's Avatar
Send a message via AIM to EWAYota Send a message via MSN to EWAYota
Quote:
how close are you to getting that done?
__________________
DJ
1994 Pickup
22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around...
Preping for SAS......
Originally Posted By Fustercluck
"Proof that Gangus did not spontaneously generate....he has relatives."
Originally Posted By Tacoclimber
"My two year old better get a job, soon..."
Reply Posted By Oly884
"I hear coal mining is a great career."
Myspace
EWAYota is offline
Old 08-25-2004, 03:43 PM   #17 (permalink)
Sweet! I just recieved mine today...a few guys from the site are gonna help me. looking forward to it.
__________________
-Kyle
Old 08-25-2004, 04:21 PM   #18 (permalink)
SolidDigital's Avatar
sounds like something I'ma have to do if you guys find any links to good deals online, it'd be great if you could post em. I have 4.10 gears and a leaky rear differential so it's the perfect time to take it apart, pop a lockright in and replace the seal
__________________
89 Deluxe Short Bed, 3.0 V6
5spd, 4x4, 31x10.5 BFG Radial Long Trails on 15x8 Pacer rims,
K&N air filter, high flow cat, Dynomax 2.5" Super Turbo muffler, Sunpro tach...
Fiamm 125db. low note horn
Pioneer 50w x 4 cd player, Polk speakers
SolidDigital is offline
Old 08-25-2004, 04:39 PM   #19 (permalink)
seaflea's Avatar
I've had a lock right in the front of mine for 10 years. Granted I do not go off road every weekend, more like once a month or so,But it has done agreat job. and is very noticeable when in 4wd but it is not hard to turn the wheel unless on a rock or hard packed road. I have heard horror stories of these blowing up in the front diff. but have not had it happen. Yet. I just hope it doesnt.
__________________
Will
WabFab Off-Road, LLC
Toyota 4x4 Parts and Custom Fabrication
updated website with lots of new products
87 runner with every bolt on available
seaflea is offline
Old 08-25-2004, 10:37 PM   #20 (permalink)
deathrunner's Avatar
Check out aussie lockers.
www.offroadlockers.com
Supposed to be smoother than the lock rite, or any other automatic locker.
__________________
IFS IS FOR LOSERS
deathrunner is offline
Old 08-25-2004, 11:07 PM   #21 (permalink)
1969-1995
All 4WD, 4 Cyl Rear TOYOTA 8" rg 30spline 0 XD-20830 $239.99
that's the closest thing I could find for my truck on that aussie locker site, would that work with my 4.10 V6 rear?
__________________
Old 08-25-2004, 11:47 PM   #22 (permalink)
MODZILLA's Avatar
Location: Bend, Oregon. 4mer Teufelhund, now a DoD Contractor
Quote:
might I also recommend that you consider re-gear at the same time. that way you can bump up in tire size and gain ground clearance. 4:88's and 33's to do some wheelin with that locker.
__________________
90 4Runner SR5 V6 3.0 The Illness: Downey K&N Intake kit/ISR/Downey Headers/2 1/2" Custom Exhaust/Hi-flo Cat/Spintech Muffler/Flex-a-lite/NWOR 1 1/2" lift Springs & 26mm T-Bars/4.88's/32x11.50R15 A/T's/Aisin manual hubs/Genuine Steel Euro Guard, Step Bumpers & Taillight Guards/Weather Guard Visors & Deflectors/Bushwacker Flares/Stripes removed/TRD Decals/Euro wheelskin.
MODZILLA is offline
Old 08-26-2004, 09:57 AM   #23 (permalink)
Quote:
man I wanna do that so bad, but it's just not in my $$$ range right now
I know nothing about gearing and lockers.. say if you get a locker and install it with 4.10's, then bump up to 4.88's a couple years later can you use the same 30 spline locker with that gearing?
__________________
Old 08-26-2004, 03:58 PM   #24 (permalink)
I believe the 8" for the regular 4 bangers is different from the 8" for the 4cyl turbo or v6. I would ask Aussie. They emailed me back very quickly and answered every and I mean every question that I had. They'd gladly help you.
__________________
IFS IS FOR LOSERS
Old 08-26-2004, 07:29 PM   #25 (permalink)
man I'm tempted to buy this one
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
A bit of a klunk when turning full lock to lock InternetRoadkill 86-95 Trucks & 4Runners 3 07-10-2007 12:52 PM
Lock Rite Lockers creeve4 Offroad Tech 18 09-17-2006 05:06 PM
What would you rather have? (33s + lockers vs 35s + no lockers) Tacoma750 Offroad Tech 18 03-19-2005 06:14 PM
Lock Right Lockers? AKennedy87 Offroad Tech 3 07-02-2004 11:21 PM
Lock Right lockers for yota? yay/nay? baileymoto Offroad Tech 15 05-25-2004 05:31 PM
2009 InternetBrands, Inc.
