Lifting a 97 TACOMA? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-11-2004, 07:44 PM   #1 (permalink)
Hey guys. Im looking into lifting a 97 or up TACOMA. I want to run 35s or 38s. What lift should i use? And what gears? Aslo, what other mods will i need? THX
Tacoma750 is offline
Old 10-11-2004, 09:12 PM   #2 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
i would suggest a SAS (Solid Axle Swap) if your going to wheel the thing, because IFS strength limit is pretty much 33's if you don't drive like a grandma, if its just going to be a street queen, then do a 6" suspension, fabtech makes one and there are some other companies out there too, and possibly a body lift if you need it, i would run 5.29's with 38's and a five speed or auto, and 4.88's with 35's and a 5 speed, if a auto i would go with 5.29' with 35's
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Old 10-12-2004, 04:17 AM   #3 (permalink)
OK, So i cant run 35s or 38s with IFS?that sux. How much is an SAS and where can i get the steps and pictures of a SAS? I know how to weld and could do it myself.
Old 10-12-2004, 09:20 AM   #4 (permalink)
Pretacopower's Avatar
Search. There's probably more threads on SAS (and tires) on this forum than any other topic.
Check out Pirate too, they've got alot of info there.
Oh, and it won't be cheap
__________________
---Ryan---
1999 V6 2WD (locked) Tacoma Prerunner
Pretacopower is offline
Old 10-12-2004, 12:06 PM   #5 (permalink)
Its not cheap = me not doin it. I'll wheel it until it breaks. Then od the SAS
Old 10-12-2004, 02:39 PM   #6 (permalink)
4Crawler's Avatar
Quote:
http://www.4Crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10 Wheel it uptil you wear out the IFS, steering rack, etc. then do a SAS.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-12-2004, 09:17 PM   #7 (permalink)
backyard_motorsports's Avatar
from what i have read on here, you can run like a basic 3" suspension plus a body lift which could allow the fittment of 35". you can buy the body lift from 4crawler. iam in the process of doing 3" suspension plus 2" body and this will allow 33" to fit nice, as for gears!! if it is a street/ highway and some dirt, a high 4.50's would work out fine
backyard_motorsports is offline
Old 10-13-2004, 04:13 AM   #8 (permalink)
om probably gonna by the 6 inch lift kit from..I forget the brand. Is it skyjacker?or one of them. Would that give me enough room for 35s?
Old 10-20-2004, 12:03 PM   #9 (permalink)
yes this will allow 35's. i know a guy where i live and he has the skyjacker lift and he has 35's on his truck.
Old 10-21-2004, 10:02 AM   #10 (permalink)
What axle should i use for the 35s? Is the stock axle ok?
Old 10-21-2004, 02:45 PM   #11 (permalink)
well this guy that i know has the trd axle. The ring gear dia. is bigger than the non trd version. BBut what i had heard is that the non trd axle is stronger than the trd because it has the carrier bearing support brackets. so i would stick with the stock but add a locker or Limited slip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Tacoma body change after 97? Xenon flares 95-97 only? blakegeee 95.5-2004 Tacomas & 96-2002 4Runners 5 10-07-2007 09:06 PM
Beginner's guide to lifting your Tacoma Tacoma Dude 95.5-2004 Tacomas & 96-2002 4Runners 0 02-23-2004 03:48 AM
Lifting a Tacoma Dashunde 95.5-2004 Tacomas & 96-2002 4Runners 20 02-06-2003 04:24 PM
2009 InternetBrands, Inc.
