Lifted torsion bar question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-20-2009, 01:38 AM   #1 (permalink)
Send a message via MSN to aerocorey
I just bought a truck with a 4" bracket lift. The driver side front was an inch lower than the passenger side. I adjusted the torsion bars to level it out. The trouble is I had to adjust the driver side as tight as it will go, there are no more threads to turn on the bolt. The passenger side is barely tight at all. That isn't with the arms cranked way up either. It's with the arms horizontal. I'm not bothered by that in itself, but I know that if the driver side drops again I can't do anything about it short of replacing the torsion bars. Are these probably my stock torsion bars or do bracket lifts come with new torsion bars? Do I need longer than stock torsion bars? This thing doesn't flex in the front AT ALL off road. I know they don't flex very well, but I'm talking NOTHING. If I don't NEED longer torsion bars with this lift I'll get some stock replacements. Maybe that'll straighten out the uneven adjustments and loosen up the ride a little. Yes, no?
__________________
Corey
'94 3.0 5 speed
aerocorey is offline
Old 09-20-2009, 07:07 AM   #2 (permalink)
James Dean's Avatar
Sounds like someone didn't get them back in the splines the same on the cam arm. Or something else is wrong with the lift.
__________________
Custom painter and Toyota Stripe and decal supplier.
http://jamesdeancreations.com
Custom Safari and Crawlin accessories.
http://www.jamesdeancreations.com/4runner_project.htm
James Dean is offline
Old 09-20-2009, 08:02 AM   #3 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
You can't get longer torsion bars, just thicker diameter. IIRC, those bars only go into the cam arm one way... If they're that outta whack, then it might not be a bad idea to replace them.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
THE ULTIMATE TOYOTA RESOURCE
'86 4Runner SR5 22R-E
4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear.
Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000
Current pics
'06 4Runner Sport
270/65R17 BFG All Terrain KO's
Quote:
Originally Posted by Junkers88 View Post
Admit it, you like reading my posts. It reminds you of the days before your runner was the monster that it is now.
BigBluePile is offline
Old 09-20-2009, 12:01 PM   #4 (permalink)
Thanks. Looks like a set of stock replacements are in my future.
__________________
Corey
'94 3.0 5 speed
Tags
bars, fanna, italy, level, lifted, require, stock, torsion, trucks, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
