Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
The desired outcome is more clearance. The only way to get more clearance is to put on bigger tires. The best way to fit bigger tires is a suspension lift and possibly a body lift. But what goes up might… tip over if you don’t extend your wheel base*? (I mean to say make your wheels wider or further apart.)
Are there downsides to a body lift? Even just a 1 inch? What will it actually do for me? Will I see less rubbing? Who makes the best one? What is better for making your stance wider? Wheel spacers or backspaced wheels? I am assuming that backspaced wheels means the outside edge sits further past the lugs allowing for a wider stance and tire. Any downsides? Im planning the sonoran 1.2 kit for a 2002 4runner limited. Done a lot of searching but I just want to make sure I have this all straight. if Thanks a lot.
__________________
Buy my Stuff! Addco, PIAA, FIRESTIK wish i could change my name to "OffRoadRunner"... "Old man gold" 2002 4runner limited: -Sonoran Steel 1.2 -Bud Built Skid and Belly Plate -Yokahama Geolander AT-S 285/75/16s -AEM CAI -TRD Cat-back -Trans cooler -De-badged (much cleaner) Soon to be added: -Stubbs sliders -Matching alloy spare -Snowboard rackS i need to carry 4! |
| Sponsored Links |
#2 (permalink) |
An in depth discussion of various lift techniques and their impact on center of gravity on the web page below:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#Lifts A 1" body lift generally has minimal affects on anything and can have some benefits as noted below: - http://www.4crawler.com/4x4/ForSale/...Kit.shtml#FAQ2 Track width (wider stance) discussed below: - http://www.4crawler.com/Diesel/Tires...ningTrackWidth As noted, a wheel with less backspacing will stick out wider. Off-road it'll be more stable but you may find some impact on steering since you have more tire scrubbing going on. If planning to get new wheels, get them with less backspacing than stock. If planning to keep stock wheels, spacers are an option.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
On an IFS truck, a suspension lift does NOT allow you to fit bigger tires. The bumpstop is still in the same place, the tire will still attempt to compress to the same position. Of course, you can limit the compression travel, but that makes the truck more tippy too.
The ONLY ways to fit bigger tires on an IFS rig without limiting compression travel are a body lift or opening the fenders (either by cutting or replacing with fiberglass, etc).
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#4 (permalink) | |
Quote:
or cut or lo-profile bumpstops...thats what I did
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#5 (permalink) |
Staff
I did a similar lift and put 285's on my '99 Runner.
No issues at all. Low-profile bumpstops are a good additional mod too...not necessary though, I never did mine. Keep in mind, I never did any hard wheeling in my Runner - mainly camping roads, water crossings and minor crawling. Fink ![]() |
#6 (permalink) | |
Quote:
__________________
#7 (permalink) | |
Quote:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
__________________
#8 (permalink) |
Oops, didn't think about bracket lifts ... yeah, they will allow you to fit bigger tires by basically the same theory as a body lift - increasing the separation between the suspension mounting points and the body (and frame in this case)
__________________
#9 (permalink) | |
Quote:
#10 (permalink) |
Yes, the tire will stuff to the same place, but you gain travel with a properly engineered solid axle lift, so you can place your bumpstops so that you either have the same travel, but can fit a larger tire OR can fit the same size tire with more travel.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action Last edited by tc : 07-22-2008 at 03:45 PM. |
#11 (permalink) | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| brembo blanks where do you getn them for a 4x4 4runner? | 1styota4X4 | 86-95 Trucks & 4Runners | 6 | 11-23-2006 02:12 PM |
| LOST ..the ultimate theory. | spacewrangler | Off Topic Talk | 7 | 11-17-2005 12:34 PM |
| 9-11 theory | Waterboy | Off Topic Talk | 27 | 04-23-2004 10:42 AM |
| The Buffalo and Beer Theory | Woodbert | Off Topic Talk | 1 | 09-18-2003 03:43 PM |
| Do 2nd Gens and 3rd gens use the same Key Blanks? | Joec500 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 07-02-2003 01:12 PM |
