YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-16-2008, 10:15 AM   #1 (permalink)
knuckle leaking??
hey guys i have some toyota 84 pick up axles and on the front one the passenger side knuckle leaks just a little on to the knuckle ball is it just the felt pad or do i have to buy the whole knuckle service kit? if so does it require any specialty tool?
KreepyKrawler is offline
Sponsored Links
To remove this ad, register today!
Old 07-16-2008, 10:21 AM   #2 (permalink)
toyota-erik's Avatar
If its leaking, then the axle seal is toast. the felt pad just keeps dust out of the knuckle.
allprooffroad.com has a nice upgrade kit.
__________________
81 Toyota P/U, 22R with GotPropane kit, wheelbase stretched 5", bobbed box, narrowed tube frame from cab back, full exo, tube doors, Warn 9000i, 36" IROKs,TR bead locks, 4 link front, 3 link rear, Fox 2.0 16" all around. Rear axle is shaved, trussed, V6 3rd, CroMo axles, 4.88, full spool, and disc brakes. Front axle is trussed, HP 3rd, 4.88, 30spline Longfields, and a lunchbox locker. Full hydro Howe desert series race pump(reworked by PSC), CroMo steering arms, 4.7:1 t-case
toyota-erik is offline
Old 07-16-2008, 10:22 AM   #3 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
To replace the pad youll have to take the entire knuckle off.
Would be a good time to give it a full rebuild if you go this route.
The knuckle should have a little grease on it but should not be a leak with grease everywere.
Youll need a good set of tools to rebuild the knuckle but its definetly possilbe for anyone to do.
Search knuckle rebuilds online and you can find the step by step
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 07-16-2008, 10:24 AM   #4 (permalink)
Allpro, trail gear (sells the most complete), and marlin sells it also.
Not a bad time to replace wheel bearings also.
Ive got a Trail gear kit for sale with wheel bearings and heavy duty rock rings if your interested PM and ill cut you a deal.
__________________
Old 07-16-2008, 10:47 AM   #5 (permalink)
dirtoyboy's Avatar
Yup...check out those wheel bearings. I would recommend replacing them with OEM Koyo or NSK bearings (unless you like changing them on a regular basis)
Check out MarlinCrawlers heavy duty axle seals..they are BEEF! no more birfield soup.....
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 07-16-2008, 10:48 AM   #6 (permalink)
x2 on the heavy duty seals from marlin the things are beef compared to stock
__________________
Old 07-16-2008, 05:19 PM   #7 (permalink)
4rnnr33's Avatar
i would say get the marlin knuckle rebuild kit or oem. dont go to all pro unless you want the worst customer service that you can get
__________________
95 4runner, 5 in tg sas and rear leaf swap, chopped, mx6 reservoir shocks, 35x13.50x15 toyo mt's, all pro front bumper, mile marker se9500c, rear tube bumper, hella 500's, rock lights, optima red top, glass fenders, tg 5.29's, lockright rear, detroit hp front
4rnnr33 is offline
Old 07-17-2008, 05:49 AM   #8 (permalink)
dirtoyboy's Avatar
Quote:
and why is this? you cant just post something like that without backing it up!
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Knuckle rebuild help. Popak2 84-85 Trucks & 4Runners 10 01-30-2008 01:27 PM
TG is out of knuckle studs Stomis Solid Axle Swaps, All Years 5 06-20-2007 01:39 PM
Knuckle implants 4-RUNNIN' FREAK Off Topic Talk 17 05-08-2006 12:53 PM
knuckle angle ? bigamigo 95.5-2004 Tacomas & 96-2002 4Runners 8 12-28-2004 04:47 PM
*HELP* Leaking oil, need to know what is leaking...(pics) UNR.Grad 95.5-2004 Tacomas & 96-2002 4Runners 25 07-11-2004 08:36 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
