Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Hey all, im new to the site and love it so far. I looked around and can't find an article that adresses this exactly. A few that kinda sounded like it might but im not sure. So after it rained tonight, I went out to test the new pro-comps in a LARGE "rain puddle", after some good enjoyment and satisfaction from the new tread, I was going to drag all my newly collected parts of earth, to a car show
haha and went to unlock the hubs, and the passenger hub wont quite turn all the way to "Free". Its close, it has happened before, but after rolling the truck forward a few feet, it went all the way with some elbow grease. But now it won't turn all the way to free.Does this mean its still engaged? Is it a big deal? How do I get it to turn all the way? I read an article on a dude named arron's truck, and he had some cv needles that broke apart and jammed it? Plz help its my daily driver! |
| Sponsored Links |
#2 (permalink) |
You'll have to take it apart. I'm guessing too much or not enough grease, both can cause that problem.
__________________
Chris 6th Annual Pismo 4runner Jamboree: Oct. 10-12, 2008 '93 4runner SR5 3.0 Auto 4WD '07 Tacoma Dcab 4x4 TRD offroad '89 F250 4x4 w/utility bed M416 1/4 ton military trailer "Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem." Ronald Reagan Semper Fi SLO 4wheelers |
#3 (permalink) |
Take it apart...clean it out and regrease it.
__________________
2006 Tacoma SR5 - Stock for now 2000 4Runner Limited 16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~Goodridge Front and rear brake lines~Rear Locker Mod~Rear Diff Extended~Surco Safari Rack~ Optima Yellow Top~ Trail Gear Sliders~6 100W Hella 500's~ Deckplate Mod w/ True Flow~ISR Mod~~Autometer Volt and Oil Press gauges~Satoshi Grille~Redline Hood Lift~Hayden 1678 Aux Cooler~Safari Snorkel |
#4 (permalink) |
will do, thanks for the input!
#5 (permalink) |
Also something to look at is the spring inside the hub. I have had 2 hubs die on me. Each time it has happened they have broke in the locked position. If you can not turn it, it could be broke.
__________________
Bru IYAAYAS!!! |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wheel bearings replaced but now Manual Hub wont engage | 88Yota4runner | Newbie Tech Section | 7 | 07-16-2008 06:17 AM |
| Manual hub stuck in (free) position | hmmwv15 | 86-95 Trucks & 4Runners | 6 | 05-27-2007 08:05 PM |
| locking hub wont go back to free | gilkey | Maintenance & Repair Archives | 3 | 10-21-2005 07:39 AM |
| Help! Got brakes apart but rotor wont seperate from hub/bearing!! | gotime242 | 95.5-2004 Tacomas & 96-2002 4Runners | 19 | 03-26-2005 08:32 AM |
