how safe are rear suspension blocks? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-16-2009, 05:35 AM   #1 (permalink)
I just bought a 93 xtra cab in great shape, the front suspension is stock but the rear has blocks under the leaf springs, im wondering if they did this because of rear sag are they safe etc.
robert1965 is offline
Old 10-16-2009, 06:35 AM   #2 (permalink)
James Dean's Avatar
Most will say they are not recommended. The greater the distance between two points the greater the chance it can move. Little thing called leverage. That means on hard cornering or while 4-wheelin the block can fold, twist, turn or worse yet break or crumble. This is mainly true if the block is taller than it is wide. Most people never have problems with a 1 or 2" spacer block for leveling.
I would double check the nuts on the u-bolts to make sure they are tight.
__________________
Custom painter and Toyota Stripe and decal supplier.
http://jamesdeancreations.com
Custom Safari and Crawlin accessories.
http://www.jamesdeancreations.com/4runner_project.htm
James Dean is offline
Old 10-16-2009, 06:39 AM   #3 (permalink)
Built2Grind's Avatar
2" should be ok but anything more than that you will have axle wrap and like what james dean said here leverage is bad on elongated u bolts
__________________
POS 3vz-e, 4x4, extra cab, SR5, 31's, glasspack, swaybarless and never going back!
Built2Grind is online now
Old 10-16-2009, 08:47 AM   #4 (permalink)
tc
tc's Avatar
Any amount of block will increase the leverage on the spring and increase the chances of axle wrap/wheel hop, etc and generally lead to shorter life for the springs.
So long as the u-bolts are tight, though, there isn't anything inherently unsafe about blocks.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is online now
Old 10-16-2009, 03:15 PM   #5 (permalink)
byron4's Avatar
dont get aluminum ones (el cheap-o from auto zone) if you do much wheeling they could buckel. my buddy's 93 truck bent his blocks and tore up all kinds of stuff...drive shaft, outputshaft, etc. the blocks had so much torque on them that they caved.
__________________
1993 4runner: ARB air locker rear. aisin manual hubs. SDORI ball joint spacers, OME 901 coils, Sonoran Steel IFS truss, 33x10.5 BFG AT's, hacked into the dash clinometer, marlin crawler sliders, custom armorology rear bumper, and a lot of custom dents.
-Byron
byron4 is offline
Old 10-16-2009, 03:18 PM   #6 (permalink)
turboboost's Avatar
I'd say it's safe in moderation.
__________________
1990 Toyota 4Runner - SR5, 22RE, 5 speed, 35" Mud King XT, a bunch of mods.
1986 Mazda B2000 - 5 speed, carb'd 2.0, the winter beater.
1979 Datsun 280zx - 2 seater, 5 speed, stripped interior, etc.
1998 Nissan Altima - 5 speed, 1981 280zx turbo snowflake rims.
1985 Toyota Pickup - SR5, 22RE, 5 speed, Xtra cab, lifted 2", 35" boggers, etc - Sold
1983 Datsun 280zx - Turbo Intercooled L28ET - Crushed.
1985 Nissan 300zx - 5 speed, race prepped, etc - Crushed.
IFS Club #7
turboboost is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
