how to make custom snorkel
Old 06-17-2012, 11:26 PM
Zpd426's Avatar
here is what I did
First I removed the old tube and mount from the fender, plugged the stock intake with a solid washer and siliconed It in.
2nd I used a 3 inch hole saw and cut a new hole in the stock airbox.
3rd I used a pvc coupler wrapped in a rubber coupler and trimmed the hole for a tight fit, then siliconed that in.
4th I cut a hole in the hood using a 3.5 hole saw designed for metal.
5th I mounted another pvc coupler wrapped in a rubber tape untill it became the right size. To the underside of my hood RE-utilizing The stock intake mount on the inside of the fender using sheet metal screws and something to act as a nut plate.
I had to use about a half inch of spacers to get the mount at the right angle so the snorkel went straight up.
And last I used a slinky like expanding intake hose so when i open the hood it expands and when I close the hood I guide it back down straight.
I need to cut some fuel line and circle it around the opening to make it a little cleaner. I have metal particles stuck the adhesive from the tape I used.... Excuse my dirt. just got back from a outing.
Snorkel and A new k&n replacement filter gave me a good amount more power and faster revs.
Total cost $25 for snorkel off ebay
$25 for hose off ebay
$20 for couplers etc.
$45 for K&N replacement filter
$20 for hole saws
Old 02-10-2013, 04:33 PM
ppipes's Avatar
toyota snorkel
Hi there, clean setup!!!
I'm doing something very similar, could you upload pics of the area were the snorkel comes out of the fender? id really aprecciate it.
Originally Posted by SPCYoda
here's what mine looks like i made it for probly around $50 if i had went out and bought every thing i needed but i already had everything but the precleaner and i got it from ebay for $26
Old 02-15-2013, 07:20 PM
SPCYoda's Avatar
Hey ppipes i sent sent you a pm but heres some pics
Sorry the last three aint that good it was dark and blowing a little snow
Old 02-15-2013, 10:22 PM
gmack192's Avatar
If you have any questions, I will try to help...
I got the snorkel head off Ebay, everything else came from Lowe's
Old 02-16-2013, 07:04 PM
  #25
SPCYoda's Avatar
here is another snorkel build by NorthIdahoyota
https://www.yotatech.com/forums/f88/...norkel-264485/
that's almost the same way i made mine but i used electrical conduit instead
Old 02-16-2013, 07:30 PM
  #26
BigBluePile's Avatar
I made a snorkel.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
09-04-2015 09:27 AM
Dakotaneu
07-27-2015 12:03 AM
MTLroadierunner
07-20-2015 03:07 PM
Quick Reply: how to make custom snorkel
