Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
HELP problem replacing upper control arms
Aye guys,
I noticed both of my upper control arms were cracked so I bought Fabtech arms to replace them with. I have absolutely no idea how to get these two bolts off on both sides of the shock. They're welded on from the front, and pretty much impossible to get to from the back. The directions say to remove the 2 bolts holding the upper control arm cross shaft to the frame. I don't know what to do. Any help is appreciated. ![]()
__________________
1994 Pickup 2WD Ext. Cab, Auto. Fabtech lift spindles Fabtech extended shackles Downey leafs 4crawler BJ spacers Fabtech upper arms Sway-A-Way torsions 31" x 10.5" BFG A/T |
| Sponsored Links |
#2 (permalink) |
if you havent gotten them off yet, the best way is to go from the top, under the hood. the drivers side isnt that bad but the passenger side sucks. best tool to use is a ratcheting boxed end wrench. also before you take the bolts out make sure you detach the ball joint from the stock arm.
__________________
94 pickup: Std Cab, 22RE, 5spd, 2wd Front: Downey Torsions, Ivan Dan Long Travel Kit, 8'' Fox 2.0 Reservoir Shocks, Hannemann Fenders Rear: Downey Shackles, Deaver Triple Pack Add-a-Leafs, 10'' Fox 2.0 Shocks 235/75-15 Yokohama Geolander AT/S Tires |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| All Pro Upper Control Arms for sale | rynavarr | Axles/Suspensions/Tires/Wheels | 0 | 08-09-2007 02:09 PM |
| All-Pro Upper Control Arms | Dr. Zhivago | Offroad Tech | 60 | 01-25-2005 07:01 PM |
| question about replacing upper a-arms | jacksonpt | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 05-12-2004 09:19 AM |
| Help w/ removing upper control arms | fourunnabilly | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 02-11-2004 12:03 PM |
| Upper control arms... | MTNTOY | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-06-2003 07:20 AM |
