Thread Tools | Search this Thread | Display Modes |
#26 (permalink) |
__________________
my rigs 89 4runner 1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed 86 pickup 1986 stock pickup 22r 31.10 BFG ATs flatbed a sad day for the 4runner "One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life." |
| Sponsored Links |
#27 (permalink) |
__________________
JASON 1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny 31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR |
#28 (permalink) |
When i was building my truck i had the 3.0/Auto/33s/4.10s. It ROYALLY sucked. I ran it like this for about 6 months until my stock rear-end started going out b/c the shop that installed my detroit didnt set up the gears correctly.
From there I sent the 3rd out to AZ for Zuk to put 5.29s in it. I put such a low gear in there b/c i needed it to run OD in the tranny. (~16 mpg) Jump forward from july 2007 to june 2008. This June we put a R150F from a 91 p/u in my 4runner. Now my configuration is 3.0/R150F/5.29s/33s. It is quite quick, but my top end suffers greatly. i run 60-63mph on the interstate at ~3000 RPM. I am now getting a solid 20.5MPG. It may be overgeared but i ABSOLUTELY love it.
__________________
-Brandon 1988 4Runner SR5 4x4 V6 5 Speed Swap SDORI 1.5" BJ Spacers~Downey 26MM TBs~Downey 3" Springs~Downey Shackles~PC ES3000s~PC ES2000 SS~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~33x12.5R15 Yoko Geolander M/Ts~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~3' Firestik II~Marlin Crawler rear~Custom Front~4X Innovations Sliders~WabFab Bikini Kit~Optima Yellow Top~SS IFS Truss. My 4Runner and Other Stuff |
#29 (permalink) |
buy the way.. where can we buy these gears to switch? I think new tires may be coming sooner than I thought. I have a couple of bent rims, thinking about buying new steel rims from toyota, having them chromed like the chrome option in 88 (the alloys were not an option for the deluxe, plus they are $370 a piece) and maybe using Bridestone dueler AT's in 31X10.5 15LT like I had on my 93 SR5 before. Those tires worked well in the mud I had to work in doing radio station proofs. 3rd gear, 3000 rpm with the 3VZE worked well. I haven't had the 22RE out int the mud so I will have to learn it.
__________________
Kristopher Erik "KD5EJO" Transplanted Alaskan in Foster OK 88 X-Cab, 87 T4Runner Like Fishing, hunting, Ham radio, flying, canoeing, kayaking, traveling, all the better with friends. Dedicated Christian. Excellent Wife. 3 Very Good Sons. Any other questions? |
#30 (permalink) |
Pick up an off road mag and you will find a lot of places to get everything from a set of gears to a completly built 3rd.
__________________
81 Toyota P/U, 22R with GotPropane kit, wheelbase stretched 5", bobbed box, narrowed tube frame from cab back, full exo, tube doors, Warn 9000i, 36" IROKs,TR bead locks, 4 link front, 3 link rear, Fox 2.0 16" all around. Rear axle is shaved, trussed, V6 3rd, CroMo axles, 4.88, full spool, and disc brakes. Front axle is trussed, HP 3rd, 4.88, 30spline Longfields, and a lunchbox locker. Full hydro Howe desert series race pump(reworked by PSC), CroMo steering arms, 4.7:1 t-case |
#31 (permalink) |
Performance Offroad Center (PORC) and Randy's Ring and Pinion seem to have the best prices. Marlin Crawler, Trail-Gear, and others have assembled third members too.
Now would be the time to do a locker or two while you're at it. When I was last looking, an assembled third with a locker was about the same price as buying all the parts and having them professionally installed, and obviously a lot less trouble.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#32 (permalink) | ||
Quote:
Quote:
4.88 gears on the auto didnt come out till around 92-93 IIRC.
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#33 (permalink) |
Because that's when they started putting 31's on from the factory ...
__________________
#34 (permalink) |
I have 42" with 5.29 gears and an auto tranny. Its not a race truck but it does ok.
__________________
1990 4runner. 42/14/r.17 irocks, spool in front. Sas, lc coils and triangulated 4-link. 1in bodylift, 7in front screen linked to 14in flip down in rear, Chopped, Bobbed 33". Wheelbase stretched 7". 1984 extra cab pickup. 7" suspension lift, 36" Radial tsl's, Bobbed 12" |
#35 (permalink) |
Dude...I had a 3.8 GPA and was a math major. You lost me... wow.
__________________
...look at that stock flex!!! :D Model: 1995 4Runner SR5 - Blue/Blue Engine/Performance: 3.0 L V6 3VZE, 5spd. Manual, everything stock so far... Suspension: Stock Tires: 31x10.50 on stock wheels Misc: Extra Power Outlet Mod (3 total outlets), 200W Power Converter Mod(for the laptop), more to come |
#36 (permalink) |
what gears would be good for 38 15.50s on my 83 pick up
__________________
1983 toyota pickup shortbed 22r weber 40mm dowmndraft hooker header 9inches of lift on 35 15 50s very slooooowww |
#37 (permalink) |
5.71 ... actually, I would suggest 6.14's in a Ford 9" or Dana 60 if you really wheel hard enough to truly need 38's...
__________________
#38 (permalink) |
Are you daily driving the vehicle? Trailer queen?
These factors can make a big difference in what gears will be best, depending how you use the truck. Another big factor is the gearing in your transfer case? stock? dual cases? 4.7 case?
__________________
'86 Toy Flatbed with a few modifications |
#39 (permalink) |
Very confused here.......I have a '93 v6/5spd with 4:10's, I put 31" BFG's on it and I can stay in 5th uphill and even accelerate on longer hills plus the speedo is dead on with no modifications.
Its no rocket but it keeps up with traffic just fine and yes I have driven modified trucks so I know what proper gearing and acceleration feels like. Considering that the 3.0 is no beast I can't see that 4:56's would be better. |
#40 (permalink) | ||
I've got 33's on my p/u with 4.10's, it goes o.k., and handles hills fine. I will also say...I have had 4runners before Auto, and 4.56 gears, from the factory, and that with 32's didnt go as good as the p/u with 33's and 4.10's.
I also have a 93 auto with 4.88's and 31's, and that is just about same takeoff speed as the p/u.
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock. It's becoming an addiction. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| tire-lift-gear help | FlatLandWheelin | Tires & Wheels | 4 | 07-23-2008 10:27 PM |
| Tire/Gear ??? | YeloSub7 | 86-95 Trucks & 4Runners | 16 | 03-04-2008 01:35 PM |
| Gear ratio math | justinking060310 | 86-95 Trucks & 4Runners | 12 | 09-24-2007 07:20 PM |
| Tire Size Odometer change, need math Wizard! | gohawks | General Vehicle Related Topics (Non Year Related) | 14 | 01-02-2006 08:32 PM |
| Tire / gear option opinions.... | Todd E | Offroad Tech | 7 | 06-30-2003 05:58 AM |
