Has any put 1 ton springs under a yota?
Old 05-01-2016, 01:52 PM
86adventurerig's Avatar
Hello all, New to the forum about to start on an 86 extended cad build. The end goal is all around adventure rig. But I am wondering if any one has put 1 ton springs under a toyota? Or if you can point me towards the right thread that would be great!
Old 05-01-2016, 01:57 PM
rattlewagon's Avatar
A comon swap is to put checy 63" springs under the rear. Google "toyota 63 swap"
Click around in here for a while too: https://www.yotatech.com/forums/f116...tickys-242840/
Welcome to the forum!
Old 05-02-2016, 09:08 AM
highonpottery's Avatar
1-ton springs off of what? If your goal is to increase load capacity, it's going to take a lot more than just some leafs.
Old 05-02-2016, 10:55 AM
MudHippy's Avatar
Not sure what you mean by that. 2WD 1 Tons use the same 30 spline axles(exc. they're 5 lug) and the same 8" rear diff as ½ Ton 4WDs. And ½ Ton 4WD frames are actually stronger than 1 Ton 2WD. Don't quote me on that though. They might be just as strong as ½ Ton 4WD frames. By that I mean they either use the same frames as ½ Ton 4WDs, or they use the same frames as ½ Ton 2WDs. Because there's no such thing as a "1 Ton" frame according to the FSM.
Meaning, if it isn't just about stronger springs, I don't know what it could possibly be. One more thing. It's not about DRW vs. SRW. Because there are 2WD 1 Ton SRW trucks.
Old 05-02-2016, 01:15 PM
well there wasn't much info to go on other than 86 xcab...is it 2wd or 4wd?
yes, the 1-ton axles are 8" diff with 30-spline. IIRC the dually version of the 1-ton is a full-floater version with the 4wd 6-lug pattern instead of 5-lug. I believe they also had lower gearing and a 4spd to help with hauling. They also had rear swaybars.
If it's just a leaf swap for more capacity, there's also the option of OME Dakar, HD version.
Old 05-02-2016, 11:18 PM
Fastbug's Avatar
I have 63 inch Chevy springs off a 1988 C2500 and there awesome, ride amazing and flex better.
llyoddickerson
11-05-2019 03:16 AM
Terofpa
All Other Toyota Swaps
7
09-17-2016 04:48 PM
SpecialScottie
04-22-2016 02:53 AM
Quick Reply: Has any put 1 ton springs under a yota?
