| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
99 Limited 4Runner 4WD ARB Bumper WARN 9500 Winch Hella 4000s My 4Runner Tons of Pics Videos of all kinds of stuff |
#2 (permalink) |
The non E-locked Taco's and Third Gen Runners used a different housing and 8.4" ring/pinion than those equiped w/ the E-Locker. The E-locker is based on the "old" 8" ring/pinion and housing, so you'd have to swap out the whole axle. ARB makes a locker for the Taco housing- it would be cheaper to put it in than buying an entire axle.
#3 (permalink) |
All 3rd Gen runners have V-6 8" rear axles, e-locker or not.
Non-TRd Taco's with open diffs get the 8.4" along with some T-100's, the Tundra and the Sequoia. With housing mods that can be found with the green button, you can put an e-locker from a Taco in your rear end. You should have a door jamb code that is referencable to charts in the search. Tentatively, V-6 autos with 16" wheels will have 4.30's while the sticks will have 4.10's. |
#4 (permalink) |
thanks for the clarification! I was under the impression the 8.4's were not usable!
#5 (permalink) |
If the axle code is not listed on the doorjamb, then it should be on the placard on your firewall.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!" |
| Tags |
| 4wd, 84, 96, 99, arb, determine, differential, gear, location, locker, number, ratio, rear, tacoma, toyota, vin |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2006 Tacoma gear ratio??? | discog8s | Newbie Tech Section | 1 | 03-15-2007 10:09 AM |
| $$ of tacoma e-locker? | jjrgr21 | Offroad Tech | 20 | 02-04-2007 09:14 AM |
| Toyota e-locker gear ratio | KZN185W | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 01-30-2007 03:13 PM |
| 04 Tacoma 2.4L Rear End Ratio | ttus | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 04-10-2006 05:27 PM |
| tacoma MT second gear | Macallan12 | Maintenance & Repair Archives | 5 | 04-25-2005 10:10 PM |
