Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
front shaft
I am in need of some help. I put a 5" skyjacker(?) lift on my 83 pickup. I was under the impression that my stock shaft just needed to be lengthened. After looking it over, I saw that it would make a great paper weight. The one I got from the shop is long enough but it will not drop enough to get to the axle, about 2” short. I was told that an IFS shaft does not flex as much as a solid axle’s. From my transfer case to my axle is 10” on flat ground.
Will a stock shaft that has been lengthened work with the angle to the front axle? I know I’m not the only one that has tried this set up, so please give me your input and thoughts. Thanks, Bru |
| Sponsored Links |
#2 (permalink) |
Not sure what you have in there now, but if it is a CV from and IFS shaft, see:
- http://www.4x4wire.com/toyota/tech/cvmod/ Other options are to use a u-joint in place of the CV joint. Why? U-joints have much more angle capability than a CV joint and they are shorter to boot, making the shaft angle less. Or run a high pinion front diff. or move the front axle forward or install a 2nd transfer case (all of which also lessen the front driveshaft angle). Or rotate the front axle housing: - http://www.4x4wire.com/toyota/tech/rotated_housing/
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
I had an 84 that I did the same size lift to and 4crawler has it. I moved my front axle forward 6 inces and used a ujoint. This did multiple things for me. First since I moved the rear axle back at the same time 7 inches I gained 13 inches of wheel base and also increased my approach angle a good bit to boot.
Pete
__________________
1990 toyota 4x4 xtended cab on a 1994 body yup thats right 31/10.5s 3slow 5speed 1999 dodge durango v8 all stock ever feel like there is too much month left at the end of the money?? |
#4 (permalink) |
I had thought that you could use the stock shaft without having to move the axle. I was thinking of pushing my axle forward but not yet. A buddy put 4” YJ springs (gaining about 6”) on his 85 and was able to use his stock shaft so I figured I’d be OK.
Back to the drawing boards. Thanks Bru |
#5 (permalink) |
Figure out what is hanging up the front shaft. Still not sure what you have up there, but you can open up the CV joint to move a little more. Around 35 degrees is about the max on the Toyota CV. See what you are getting now and if less than that, you have room for improvement.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Front drive shaft | ezera | Offroad Tech | 4 | 05-16-2008 06:26 AM |
| Front D shaft | Justinvd | General Vehicle Related Topics (Non Year Related) | 1 | 03-18-2008 02:54 PM |
| front d shaft question | cherokeechief79 | Offroad Tech | 13 | 12-05-2007 11:42 AM |
| Front cv shaft seal | Firefightertaco | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-08-2006 07:30 PM |
| Front drive shaft going, going.... | HaveBlue | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 12-27-2002 12:32 PM |
