Front SAS leaf spring question...
Old Dec 10, 2005 | 07:24 PM
6lug's Avatar
If I ordered the 4" springs with either All Pro's or Marlin's, but wanted a little less lift, could I take a leaf out of the springs? Would that work, or would it mess something up? The reason I asked is that I wanted to order the 3" springs from All Pro, but they said the 3" springs werent made for full bodied trucks, etc, but rather for buggies and stuff....they have a soft spring rate, and then after they settle, Im afraid they'll flex to a negative arch. So in order to get a little less lift from the 4" springs, I was just going to take a spring out of the pack...let me know what you think. Alex
Old Dec 10, 2005 | 08:43 PM
Silver_Truck's Avatar
why not just run rears up front? they're free (if you change your stock rear springsm if not you can get em dirt cheap)
Old Dec 10, 2005 | 09:34 PM
4Crawler's Avatar
Well, with the 2nd gen 4Runner, you have coils in back. You would need to get at least 2 sets of stock rears to make up a custom pack. But yes, you can take a leaf out of the 4" springs, usually the 2nd to the bottom for less lift. However, you may find you need to run tall enough bumpstops to keep the tie rod and drag link off off of the frame under compression. You can run the 1 less leaf until the springs settle a bit, then add that leaf back in to restore the ride height if needed.
Old Dec 10, 2005 | 10:26 PM
6lug's Avatar
thats what i was thinking....about the bumpstops and adding that leaf back later. The only reason I wasnt going to use any other type of leaf (ie....a rear pack) is because I dont want to separate the SAS package....I talked to all pro, and they said that if you buy the package, you end up saving about 15 % over buying the parts separately. So im just going to get a kit, and then make do with that. Thanks guys...Alex
Old Dec 11, 2005 | 09:53 PM
ah ha, thanks Roger...I missed that minor detail. Personally I'd go with marlin or even All Pro but not Trail Gear. What's the price diff now between marlin and all pro?
Old Dec 11, 2005 | 10:01 PM
AxleIke's Avatar
Those kits are pretty nice. Be interested to see what you think of the install...the other SAS going on right now is moving along at a very rapid rate. Keep us posted, and good luck with the spring dilemma
Old Dec 12, 2005 | 04:16 PM
6lug's Avatar
I think the price dif now is about 200 b/c marlin's is on sale.
Thanks for the encouragement.....it will be a little while before I start this project b/c Im still in school, but this summer, it should happen.
Thanks again...Alex
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
shisha1999
Sep 21, 2015 08:22 PM
boogiewoogie
Jul 24, 2015 05:10 AM
Nickdigg
Jul 7, 2015 06:04 AM
