Front Range off-Road Transfer Case Mount installed!
Question: do you know if this could be used to replace the existing transmission / transfer case mount? Actually cut out the factor cross member? Would it be strong enough?
Comment: this would be real nice for someone looking to tuck everything up between the frame rails.
Absolutely, that is in fact what it's primarily designed to do. We decided to run it in conjunction with the stock mount since we jump and really abuse this truck. The idea behind this product was to gain ground clearance by removing the stock mount. It is a really versatile product, it can be used to mount a marlin dual case as well. You could do as you said and tuck everything up and then you could skid plate right across the rails if you wanted to.
Looks good. Those are a really great product for those who could roll their own belly pan.
I would get one if I did not have torsion bar mounts in the way.
Too bad we did not make it back to Carnage in time Jim, then we could have taken a look at this in person.
Flygt, if you plan to keep your IFS, Total Chaos is just releasing their "Caddy Kit 2.0" that lets you mount single or dual coil-overs and remove the t-bars on 1st gen IFS equipped trucks! We are installing this new kit on our '89 this month, it should work really well. I am thinking though that you would rather put that kinda $$$ towards a live axle setup...
Yeah, the cost becomes a wash if you do it yourself and my money is better spent on a solid axle and Longfields.
Nice product and Mr. Ellinger's Taco is sure a sweet truck. Any pics of the crossmember on your rig?
Yeah, all the pics except the first one of Brians truck are of our rig, We just used Brians truck in the intro of the article since it is such a sweet pic! We also just got a fabricated FF Tundra width rear axle housing from Brian, that's going in the Taco next, we just need to find the time to re-fab all of the mounts we had to make for our stock axle (shock mounts, spring pads, etc.) and we are waiting for custom superior axle shafts as well. Already got the ARB and superior 5.29's...
You get enough width out of the long travel stuff to match a Tundra rear? WOW, that blows my mind.
Sorry for the oversight on the pics, I never looked really close at them.
with only 3" lift, 35x12.5's (33x10.5's pictured) and Tundra width, you understand why we can do this without much fear of rolling!
This pic is not tilted at all, look at the background for proof.
No worries about missing the detail pics...
[IMG]edited image due to it not being hosted on my site[/IMG]
http://www.r65.org/tacoma/20020908/images/IMG_0286.jpg
Sure would be nice to have a Tundra rear axle and a TC long travel kit though!
Thanks man!
I like your set up!!
Yaul got a Tundra rear axle to match the width of the TCLT kit?
This is the set up I've been ponderin over SAS'n. Then run some 35x10.5 Boggers and run the hobby stock crawlin' class. I've got at least 2 years to weigh it out though so I'm sure it'll change a hundred times before then.
BTW: I have a similar crossmember in the test phase for SAS'd Tacomas so they can run a front drive shaft. When it's done, I'll share pics. Nice write up man.
Yeah, we got the Tundra width housing to match the increased width up front from the LT setup. I am really excited to get that FROR housing onto the truck but it will be a little while longer since we have a few other projects taking precedence. It's hard to have that FROR housing in the corner of my eye all day knowing it will be a few months until we get to slap it together.
We thought long and hard about a live-axle front end before going with the LT on the Tacoma. However we do plan to install a 4-link coil-over FROR/Toyota axle under our 4Runner. There are clear strength's and weaknesses to both. I'd say for a person who's handy with a lincoln/miller going SAS is always a great choice! If you are not sure about going back to stock or don't have welding experience, LT kits are great since they bolt right up to factory locations.
I look forward to seeing what you came up with for a t-case X-member, be sure to keep us posted.
Here's our first SAS Tacoma....(did you see it already?)
https://www.yotatech.com/forums/f88/inprogess-sas-98-trd-tacoma-31120/
On a Tacoma it works alot better since the tank is up alot higher. I would have bought one, if it would have done anything.
