| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Dual Transfer Case Questions
__________________
Alan 1996 Supercharged 4Runner Limited Hi Altitude 4Lo A 4WD club for Colorado and surrounding states |
#2 (permalink) | |
Quote:
2 - Marlin's A340F->gear drive tcase and Mariln gear drive tcase -> your tcase. Plus shorter rear shaft and longer front shaft. Possibly interior mods and crossmember mods. 3 - sure 4 - crossmember, possibly lengthening the speedo cable. 5 - only if you wheel.
#3 (permalink) | |
Quote:
__________________
#4 (permalink) |
1. http://www.marlincrawler.com/htm/tra...c.htm#topshift
2. he is saying the adapter to connect your A340F to the reduction box of the old tcase |
#5 (permalink) |
I just put one of the Marlin dual ultimate crawlers in my rig this past weekend. Big job, but I am very happy with the results.
![]() Mine has a 3.0 5spd, so I can only offer some help. I got the 3.0 to 4cyl TC adapter from Marlin. Keep in mind that the majority of Toyota 4cyl transfer cases have 21 spline input shafts. My 3.0 tranny had a 23 spline output shaft. You will need to change your case(s) so they both have 23 spline for strength and compatibility. The job can be done with standard tools. A tranny adapter for a good floor jack is very helpful. Angle grinder and a welder/ or torch might be required as well. Speedo extension can be purchased from Marlin. I got one, about 6" long. Very helpful part. You may also wish to purchase their multiple hole pattern flanges. You'll have a better shot of matching up to you newer driveshafts without having to re-drill. Also consider getting a boot for the new shift lever to help keep down road noise, dirt... and give a cleaner, more finished look when you are all done. Can find all those parts on this page: http://www.marlincrawler.com/htm/tra...e/tcase_ac.htm I had to modify the shift levers themselves to make everything fit together. IN a 5spd, I've got three sticks I needed to make clear each other in all configurations. I got close, and can get every combination but 4th and 4.7 low... but I have an idea about that to try later. You may have less issues with an auto, but to change stick angles I used a welder. Others have had luck with a torch and bending. The problem with both methods is that there is a hard rubber sleeve that mates the upper lever to the base stick. Once that melts... shifter comes apart. In my opinion, the crawler is more "worth it" if you currently have a manual tranny. Although I have not driven an auto with a crawler, the rigs I do runs with that are auto equipped can generally modulate their speed pretty well already. I guess the increase in low end torque might be nice. I'd like to learn more about how a crawler helps guys with auto trannies.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - visit the sticki chronicles
#6 (permalink) |
Or I could just save myself some time and install this:
http://www.marlincrawler.com/htm/tra...e/taco_box.htm It's only $150 more than building my own. So now my question is: With the TacoBox setup, it's apparent I have to relocate my push-button 4WD lever back. Or do I retain that lever at all? Is it simply replaced?
__________________
Alan 1996 Supercharged 4Runner Limited Hi Altitude 4Lo A 4WD club for Colorado and surrounding states Last edited by HaveBlue; 02-27-2007 at 02:32 PM. |
#7 (permalink) |
inchworm also has a tacoma double case setup as well...in a gear driven flavour ala pre taco tcases. http://www.inchwormgear.com/store/index.php?cPath=21_38
i'd guess your 4WD push button can go in either front or rear t, since its only a switch. the 2 levers will let you choose your combo of 4hi, 4 low, or 4 double low.
__________________
sonny ------- 1998 4Runner LTD. Fabtech CO fronts, OME/Pro Comp rears, SS rear links, Revtek diff drop, oem elocker, ARB RD90, 4.88's, 315/75/16 MT/R's on FZJ-80's, Trail Gear sliders, ARB Prado Bar, 1.5" 4Crawler BL, Tundra Brakes, wabfab disco's, IPF's...satoshi'd deckplated & ISR'd. SOLD!!! new ride: 1997 FZJ80. ome/arb/bfg/etc. when clinton lied..nobody died |
#8 (permalink) |
Be sure to talk to Flygtenstein - he has the setup you're looking at.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#9 (permalink) |
Am i missing something? Doesn't he have a tcase that is the wrong drop? I could be off, just asking for clarification.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#10 (permalink) |
Doing the cases in and out took me an afternoon with help.
Putting them in from a stand still having never done it before would be a handfull, the coupler is a turd. I have a passenger drop front, you do not. I am not sure I have seen this done with the push button case. It is worth it. With the auto, I do most wheeling in 4.7 low. I use stock low for wheel speed obstacles. I use double low to entertain myself at parties.
__________________
Ease on down the road. |
#11 (permalink) | |
Quote:
I am a moderate mechanic. I can do most things, but i cannot do them fast. I only did a single case, and it took me 12 hours driving to driving. I did it in a regular garage, but was using air tools, and everything...even there, from start to case out and apart, took me 5 hours, the rebuild took another 4 and then 2 to get it back in (hour for lunch). I would imagine, for me, trying to do both cases at once, probably 15-17 hours.
__________________
#12 (permalink) |
I went with the Taco Box.
The swap took me and a buddy about 8 hours in the driveway. The biggest bugger for me was getting all 3 shifters to clear each other, the interior, and the body. Cheese is right the coupler is weird, especially since there are no instructions. (Cheese, I think my coupler is different than yours, the newer design places the tranny output seal inside the front case with a machined aluminum extension) Tips: Get a set of drive shafts made up ahead of time Be prepared to weld, test, re-weld, test, re-weld, test the shifters Get a good tranny jack Opinion: With an auto a second stock case may be low enough (save $500 over the 4.7) Question: Since you haven't wheeled with 4.88's and a front locker yet, why look into a dual case now?
__________________
'00 SR5, "Highlander" Dual Cases, Aisin Hubs, E-Lock'd, Cryo'd, Chromo'd, ARB'd, 315's, Sonoran Steel Bumper, Lift & UCA's, 4 Crawl 1" BL, Armored...etc. F-Toy #081 in progress Dual Cases, 30 Splines, 5.71's, E-lockers, Hydro-Assist, 37's, DOM Hendrix Chassis, 80Proof, ORS, Sonoran Steel...etc. Last edited by Albuquerque Jim; 02-27-2007 at 10:56 PM. |
#13 (permalink) |
I went with the Taco box and it took me about 3 hours to install the box and drive shafts. (that I purchased ahead of time, then had modified before hand)
It took another hour just to get the shifters to set in just right, so they all cleared each other. Once this was done about 2 more hours modifying the cup holder and adding the boot, but that was done about a week later. |
#14 (permalink) | ||
Quote:
__________________
"Prepare for the worst, hope for the best" 2002 Tacoma Doublecab - "TURTLE TACO" Just a bunch of bling on a truck...
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| WabFab Off-Road Dual Transfer Case Adapter Kits | waskillywabbit | Vendor Advertising | 1 | 01-04-2007 07:57 AM |
| Dual Transfer Case Question | Yotaboy | Offroad Tech | 7 | 06-01-2006 10:11 AM |
| dual transfer case, what will it do for automatic | i_rifiyou | Offroad Tech | 14 | 12-12-2005 04:46 PM |
| 2nd gen automatic dual transfer case option | jay-q | 86-95 Trucks & 4Runners | 2 | 12-08-2005 02:08 PM |
| 3rd Gen transfer case leak questions | aowRS | Maintenance & Repair Archives | 7 | 07-27-2005 02:07 PM |
