| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Dual Transfer Case Question
#2 (permalink) |
driveability should not change
you can lengthen your current drive shaft
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs |
#3 (permalink) |
Thanks for the reply
#4 (permalink) |
I have an '88 with dual cases. Driveability is not affected by doing dual cases.
Where in VA are you? I had my rear shaft shortened and my front shaft lengthened by a heavy truck spring shop in Sterling. I think the place is called Chantilly Spring Works. They generally do dump truck springs, but I got my shafts done there and they have made me custom leafspring u-bolts a couple of times.
__________________
Click here to buy rock crawling stickers and shirts |
#5 (permalink) |
Make a square shaft for the front(much cheaper/stronger). Search pirate or just ask superjoe83. He has one.
__________________
Chris Fischer 3D 85 4Runner SR5 | 33" BFG M/T on flat black rims | Chevy springs | Custom Grab cage with overhead cb mount | Custom fabbed center console | Freshly rebuilt axle with IFS hub/caliper swap | Rock Sliders | Lots more... In Colorado, Dig. |
#6 (permalink) |
Im on the coast. I talked to Stardard Machine shop in Chesapeake and they said they would have to see them first. He said that on some of the imports they have to make a whole new drive shaft. How much did yall spend at the machine shop? I dont think a square shaft would be good because you cant balance it, maybe Im wrong. Ive heard of people using the rear shaft on the front. Can you do that
? Do I need to get ride of the cv joint on the front shaft?
#7 (permalink) |
Do not make a square shaft unless you NEVER run on the road in 4wheel drive, for example, if you never get snow. You probably can't safely run a square shaft at much above 20 or so.
Key word there is safely, i'm sure people have done it, it's just a dumb idea.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#8 (permalink) |
Not when it's sleeved with uhmw polyethylene.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Dual Transfer Case Questions | HaveBlue | Offroad Tech | 13 | 02-28-2007 04:52 AM |
| WabFab Off-Road Dual Transfer Case Adapter Kits | waskillywabbit | Vendor Advertising | 1 | 01-04-2007 07:57 AM |
| tranny and dual case question | wifesaysimadumbass | Offroad Tech | 6 | 05-07-2006 07:50 AM |
| dual transfer case, what will it do for automatic | i_rifiyou | Offroad Tech | 14 | 12-12-2005 04:46 PM |
| 2nd gen automatic dual transfer case option | jay-q | 86-95 Trucks & 4Runners | 2 | 12-08-2005 02:08 PM |
