dual case question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-12-2009, 12:33 AM   #1 (permalink)
kinzer's Avatar
dual case question
i tried searching and couldn't find anything useful so ill just ask
im building dual cases, i have a set of 4.70 gears 23 spline, and a 23 spline adapter with 23 spline input gear in the rear case, i am also running a v6 transmission so i need to match the 23 spline output shaft,
my question is, is there any harm with putting the 4.7 gears in the first case and leave the 2.28 gears in the rear case. iv heard about it causing failure to the rear reduction box due to input shaft failure of a 21 spline. but since i have the 23 spline set up, will it be ok?
__________________
They call me the "Short Bus"
89 pickup SR5 3VZ-E 5 speed 4X4
5" HD trail gear sas | rock sliders | u bolt flip kit | 6" shackles | 38X12.50 TSL's | led rock lights | 5.29's
dual t-cases 2.28 and 4.70 | welded front and aussie locked rear | bud built flat belly skid
marlin crawler rear bumper | trail-gear front bumper | x-plod amp & kicker cvr 12
Flowmaster | K&N system | 125" wheel base | cb
http://www.youtube.com/watch?v=yQbF4ThlNEI
Quote:
Originally Posted by Matt16 View Post
but if you only got 3" to start with, 5" is huge...
kinzer is offline
Old 09-12-2009, 05:28 AM   #2 (permalink)
BAMF_CT2004's Avatar
thats a good question. have you tried marlins forum or pirate? i cant help with that one because I dont have a dual case YET and have looked that much into them.
__________________
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some muscle.
Quote:
Originally Posted by GreenFlames View Post
just because you called me a web wheeler what ever that means.
BAMF_CT2004 is offline
Old 09-12-2009, 07:03 AM   #3 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
IMO if you build duals you should get a chromoly output shaft from Longfield anyway so you will be tearing both cases apart regardless.
It's early and I haven't had any coffee, but you want the 4.7 gears in the rear case.
waskillywabbit is offline
Old 09-12-2009, 09:32 AM   #4 (permalink)
neoworm0's Avatar
Send a message via MSN to neoworm0
IT has nothing to do with the number of splines on the input. It's more about how the torque is multiplied through cases. When you put the 4.7's in the front case you end up stressing the coupler a lot more than you would with the 4.7's in the rear case.
If you are using two gear drive cases I would reccomend putting the 4.7's in the rear case. Is there some reason you don't want to do that?
There is a very good thread on this subject on Marlin's site or maybe Pirate.
__________________
1995 Toyota PU SR5. 2000 3.4l V6 and a few other mods.
my album:
http://www.yotatech.com/album.php?albumid=101
my SAS:
http://picasaweb.google.com/areinhol...eat=directlink
www.overlandcanada.ca
www.alltracwagon.net
neoworm0 is offline
Old 09-12-2009, 10:07 AM   #5 (permalink)
kinzer's Avatar
actually it does, i know it causes more stress on the rear case, especially with the stock 21 spline, thats why i stated i have the 23 spline because its stronger.
the reason i am asking this is i already rebuilt the rear case and its all sealed up, and id rather not have to tear back into it but i might as well to be safe. that and i was curious because i knew it was a rule of thumb to put the 4.7 gears in the rear case but with stronger gears would it really matter.
__________________
kinzer is offline
Old 09-12-2009, 10:13 AM   #6 (permalink)
neoworm0's Avatar
It's not just the input shaft you need to worry about, I'd be concerned aout stripping the the coupler more (Speaking from experience). But you seem to already know all the answers so do whatever you want then.
__________________
my album:
my SAS:
neoworm0 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
