dual batteries w/out isolator - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-24-2007, 03:45 PM   #1 (permalink)
Send a message via AIM to dfoxengr
first off ill get it out of the way that i hate wiring, and dont uderstand much, which is why im ME, not EE.
ive read a lot of writeups but all of them seem complicated and expensive.
anyways, i want the simplest setup for dual batteries, and im wondering why i cant just wire 2 in parallel with a disconnect for the piggyback so i can run it independantly of the main.
i dont want a starter only battery which is what im reading most people do this for.
ill have one in stock location, and another in my bed box(which will have my converter and compressor and aux outlets wired to it)
i can then leave the disconnect out for normal use, and when i need a recharge on the aux., or a jump-start ill just stick in the disconnect in and go.
also planning on a higher output alternator at the same time.
what would be the downsides of this method?
__________________
Fox Design Works
http://www.honda-tekh.com
- Owner
A better Honda / Acura community forum.
dfoxengr is offline
Old 02-24-2007, 04:06 PM   #2 (permalink)
4Crawler's Avatar
Sure, that will work. No different that using a solenoid like I use on mine. A solenoid is nothing more than an electrically controlled switch.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 02-24-2007, 05:12 PM   #3 (permalink)
tc
tc's Avatar
When I did the competition car audio thing, we never used isolators due to the voltage drop across them. Wired all the batteries in parallel.
It is CRITICAL to have a fuse on the wire to the back within 18" of the front battery, and I would use BIG wire, like 1/0.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 02-24-2007, 06:03 PM   #4 (permalink)
so its not looking like there are any downsides. thats great, makes my life tons simpler. and yes ill use some big wire. thanks for the tip.
and what size fuse 100A? i have no idea about lots of this stuff.
ill also probably upgrade the stock alternator wiring as well.
another ?. if i were to just have to use the duals as a stick welder, could i unground them from the chassis and hook up my leads to the aux one, both in parallel and only connected to eachother, and not burn anything up?
thanks again.
__________________
Fox Design Works
- Owner
dfoxengr is offline
Old 02-24-2007, 08:18 PM   #5 (permalink)
tc
tc's Avatar
You'll want to connect them in series for welding I think.
And you're looking at a 300 - 500A fuse - whatever the CCA of the battery is and what size wire you use.
__________________
tc is offline
Old 02-26-2007, 09:47 AM   #6 (permalink)
4Crawler's Avatar
Yep, series for welding, I have both my batteries "floating" so when I unplug them from the vehicle, both + and - terminals are not connected to anything. Then I can plug in some jumper cable extensions and tie the + to - on one set to get 24 volts. I find that it is very hard to strike an arc w/ 24 volts, so usually end up needing another battery (in series) to jump to 36 volts for good welding:
- http://www.4crawler.com/4x4/CheapTri....shtml#Welding
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Dual batteries under the hood BajaTaco General Vehicle Related Topics (Non Year Related) 85 03-01-2006 05:23 AM
Dual Batteries Installation Gangus2006 Vehicle Audio & Home Entertainment 29 06-03-2005 06:31 PM
dual batteries rugerm44 95.5-2004 Tacomas & 96-2002 4Runners 8 11-10-2003 04:58 AM
Dual Batteries Churnd 95.5-2004 Tacomas & 96-2002 4Runners 3 10-02-2003 05:01 AM
dual batteries? doink 95.5-2004 Tacomas & 96-2002 4Runners 5 02-09-2003 09:58 AM
2009 InternetBrands, Inc.
