Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Downey Pre-Runner AAL?
I recently stumbled across the Pre-Runner AAL sold by Downey and had a couple of questions about it. Does it work with stock springs or just the Downey ones? Does it actually make a big difference? I've been lurking here for a little while and couldn't get a good answer from searching. If I missed something in my search, point me in the right direction. Thanks in advance.
| Sponsored Links |
#2 (permalink) |
yes they work with stock springs you just remove the overload leaf and put this in its place. and yes, they made a big difference on the way my truck handled and rode. you just missed the ones i had for sale in the classifieds.
__________________
94 pickup: Std Cab, 22RE, 5spd, 2wd Front: Downey Torsions, Ivan Dan Long Travel Kit, 8'' Fox 2.0 Reservoir Shocks, Hannemann Fenders Rear: Downey Shackles, Deaver Triple Pack Add-a-Leafs, 10'' Fox 2.0 Shocks 235/75-15 Yokohama Geolander AT/S Tires |
#3 (permalink) |
Ok cool, thank you. Would I be right in assuming these work with any leaf pack then? I plan to eventually get the OME system and don't want to buy stuff now that won't work with it.
#4 (permalink) | |
Quote:
NOTE: just make sure that Downey sends you the correct size. There are more than one length. If it is NOT the correct length (to provide the correct stagger) the AAL WILL bend your springs beyond repair. Seen it happen many times ![]()
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Downey Pre-runner add-a-leafs | Robert m | Axles/Suspensions/Tires/Wheels | 1 | 07-22-2008 09:24 AM |
| pre runner | 90inworks | Offroad Tech | 2 | 11-23-2007 10:58 PM |
| 2001 Pre Runner - AC Leak | Thomas J. | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 05-06-2006 06:34 PM |
| Pre-Runner | Matt013086 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-13-2005 01:49 PM |
| Pre runner stuff | Corey | Off Topic Talk | 1 | 09-15-2002 12:30 PM |
