diff help fast!!
Old Nov 25, 2004 | 06:27 PM
forty4's Avatar
diff help fast!!
ok, i'm trying to take off my rear diff. I got the bolts off, that are towards the driveshaft, and got that loose. do i need to pull the axles out the sides or take off the bolt thats on the pinion? or should i be able to just pull the diff housing off. 8" axle too. i want to get this done and any help would be much appreciated. thanks guys!
Old Nov 25, 2004 | 06:32 PM
waskillywabbit's Avatar
Talking
Yep, you gotta pull the axles out a bit just enough to clear the diff so it'll pull out.
Old Nov 25, 2004 | 06:35 PM
AznSky's Avatar
when we regeard mine, we pulled the axles out enough to be able to pull the R&P out. So yes.
edit: Brian beat me to it.
Where are you located in IN?
Old Nov 25, 2004 | 06:44 PM
BruceTS's Avatar
The rear brake hard lines will need to be disconnected, but if your savy, you can loosen the mounts, but leave the lines attached and stretch them enough that you can pull the axles out just enough to get the third member off.
Old Nov 26, 2004 | 07:13 AM
forty4's Avatar
wow that was fast. got her apart. disconnected the parking brake and undid the brackets for the hard lines adn got the axles out far enough. thanks
puddlepirate
Jul 30, 2016 06:29 PM
live4soccer7
May 11, 2016 06:52 PM
Scotttekoch
Sep 28, 2015 10:30 PM
Odin
Sep 26, 2015 06:56 PM
Project90
Sep 24, 2015 11:40 PM
