| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
deep water help
#2 (permalink) |
You don't need to worry about the exhaust. If you don't have extended diff breathers, you should get some unless you want to change your diff fluid after each crossing. Your fan could get seriously damaged as well, so I would recommend an electric fan that can be shut off before crossing. Not sure about the alternator.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k) |
#3 (permalink) |
the fan, i almost forgot about that one thanks.
#4 (permalink) |
The stock fan is a clutch fan. The clutch will allow slip once it's in the water so it won't be damaged or force the blades in to the radiator. Just don't go long periods in deep water as the clutch in the fan can overheat. Limit the time limit in deep water and you shouldn't have any fan issues.
Of course, elec. fans are nice and free up power but it's just another thing to go wrong and an unnessasary cost in my opinion. They're not cheap. Plus you have to remember to shut em off BRFORE entering the water or you WILL damage the blades as well as probably the fins on the radiator.
__________________
Yoats & stuff |
#5 (permalink) |
ok sounds like i don't need a different fan. yeah they are pretty expensive. the cheapest i could find was like $60. well thats one less thing to buy
#6 (permalink) |
When my alternator got soaked in muddy water it was done for. I took it apart and cleaned and cleaned but it was DOA. I had to shell out $170 for a new one.
Lamm
__________________
-1992 4Runner SR5, Destroyed by fire. Lots of mods. I will miss it. -1995 4Runner SR5 Limited, Also known as the money pit. Becoming a trail rig now. -2004 Tacoma SR5 TRD, My new daily driver. I love this truck! |
#7 (permalink) |
Water won't hurt the alternator. It's output will decrease whilst it's wet but it'll dry out and work properly.
Mud on the other hand will destroy an alternator. a
__________________
Yoats & stuff |
#8 (permalink) | |
Quote:
Food For Thought Lamm
__________________
#9 (permalink) | |
Quote:
__________________
1997 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1998 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1991 Toyota 4Runner 4 Door, 3.4l (5VZ-FE), 5-Speed (R150F), 4WD, 32's, 4.10's |
#10 (permalink) | |
Quote:
![]() ![]() ![]() ![]() My point was that if he went mudding or got mud in his alternator, it's OK to spray it down with the pressure washer/hose at the car wash or home. The water won't hurt the alternator. Now, if he goes muddin' and thinks it cool to leave the mud on there fer a few days, chances are, it'll eat his alternator up. Thoughts Thought Out ![]() SloPoke
__________________
Yoats & stuff Last edited by SloPoke; 11-17-2004 at 09:20 AM. |
#11 (permalink) | |
Senior Member
Quote:
__________________
98 Limited 4x4, Rockstomper skid, Rockware Front bumper, Warn HS9500i, 1" RB BL, Tundra coils front & OME HD rear, Nuke quick discos, diff drop'd, 305/70/16 Baja Claws, Electric Locker, couple of battle scars, but nothing major :) |
#12 (permalink) |
I've had mine in 46" of water with no water specific mods without a problem.
__________________
Cory Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here 04 Dodge 2500 Cummins - DD/Tow Rig 02 Z06 Corvette - Weekender 94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727 72 Buick GS - i.e. the project that will never get done. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Deep Water..... | keithguts | 86-95 Trucks & 4Runners | 8 | 07-18-2007 01:20 PM |
| water too deep | 94 sr5 | 86-95 Trucks & 4Runners | 7 | 03-13-2006 05:29 PM |
| Running deep water and mud..? | Tacoma750 | Offroad Tech | 8 | 03-08-2005 08:50 PM |
| deep water | Mikronized | 95.5-2004 Tacomas & 96-2002 4Runners | 22 | 01-09-2004 02:00 PM |
| water, how deep ?? | LC Lite | 95.5-2004 Tacomas & 96-2002 4Runners | 27 | 06-11-2003 07:46 PM |
