YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-28-2008, 10:54 AM   #26 (permalink)
drew01taco's Avatar
I'm about to put 265/75/16 on my stock 2001 4x4 tacoma and i know they are going to rub a little in the front and i was thinking about getting a 1.25" daystar lift in the front. Do yall think it will prevent it from rubbing. Also, I found a website (http://www.wheelersoffroad.com/9504tacodstrlift.htm) it says that the top spacer alone will not affect the ride, but the bottom spacer does.
__________________
2001 tacoma stock, V6, 5sp., brushguard, 12" subwoofer
drew01taco is offline
Sponsored Links
To remove this ad, register today!
Old 05-08-2008, 09:08 AM   #27 (permalink)
Bdog's Avatar
I am running 265s
On my 04 and there is no rub. I am lucky to have the V6 TRD coils in the front for about an inch of lift but if you use the stock rim you will be fine. Astheticaly, the leveling out looks great!
Brandon
__________________
'04 Tacoma SR5, Extra-cab, 4WD, 2.7L, 5-speed, 265/75-16 Revos, Daystar 1.25 spacer and '00 TRD struts in the front, Deaver AAL in the rear, matching silver jeraco truck cap, Turn signal relocation, valance clearancing, and 2 Hella 500s.
Bdog is offline
Old 05-08-2008, 01:57 PM   #28 (permalink)
drew01taco's Avatar
thanks and i agree. i'm thinking about doing like a 1.5" leveling kit so it willl look a little better and level up. but i'm also thinking about getting some black cragar rims when i get the tires so idk but i'll see.
__________________
Old 06-04-2008, 10:15 AM   #29 (permalink)
Bdog's Avatar
Rims
Check wheelers offroad for the black steelies and make sure you get the 16 inch ones because the "guaranteed" fit on 16s from his 15s isn't really true. My bro couldn't get the 15s to fit his '00 TRD that came with 15s!
__________________
Bdog is offline
Old 10-08-2008, 01:46 PM   #30 (permalink)
brianyaklin's Avatar
Quote:
Originally Posted by trainerdude View Post
i know cornfed spacers are great. i just wasn't to happy with the ride quality but that probably came from the cheapo ranchos. does anyone know if daystar uses a different setup than just the space on top of the coil pack?
i have a daystar 2.5 coil spacer lift on my 00 runner, the ride is nice, too nice for me, i like it to be more stiff, but i've had them for over a year, and they are still handling very well.
__________________
:2000 4Runner 2.7L 5spd 2wd :(
:32x11.5x15 bfg a/t
:Daystar 2.5 coil spacer body lift
:front custom steel braided brake lines
:herculined front and rear bumpers
:HID conversion
brianyaklin is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1.5" daystar spacer lift okay? TRDrunner 95.5-2004 Tacomas & 96-2002 4Runners 20 02-08-2007 03:34 PM
front daystar spacer from wheelers TX2RUNNER1997 95.5-2004 Tacomas & 96-2002 4Runners 4 04-14-2006 10:44 AM
Lifts...solid (Cornfed) vs Plastic (Daystar) nrgetic99 95.5-2004 Tacomas & 96-2002 4Runners 4 03-02-2004 05:46 AM
Daystar Coil Spacer questions. JACKLEE 95.5-2004 Tacomas & 96-2002 4Runners 4 03-27-2003 07:02 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
