Thread Tools | Search this Thread | Display Modes |
#26 (permalink) |
I'm about to put 265/75/16 on my stock 2001 4x4 tacoma and i know they are going to rub a little in the front and i was thinking about getting a 1.25" daystar lift in the front. Do yall think it will prevent it from rubbing. Also, I found a website (http://www.wheelersoffroad.com/9504tacodstrlift.htm) it says that the top spacer alone will not affect the ride, but the bottom spacer does.
__________________
2001 tacoma stock, V6, 5sp., brushguard, 12" subwoofer |
| Sponsored Links |
#27 (permalink) |
I am running 265s
On my 04 and there is no rub. I am lucky to have the V6 TRD coils in the front for about an inch of lift but if you use the stock rim you will be fine. Astheticaly, the leveling out looks great!
Brandon
__________________
'04 Tacoma SR5, Extra-cab, 4WD, 2.7L, 5-speed, 265/75-16 Revos, Daystar 1.25 spacer and '00 TRD struts in the front, Deaver AAL in the rear, matching silver jeraco truck cap, Turn signal relocation, valance clearancing, and 2 Hella 500s. |
#28 (permalink) |
thanks and i agree. i'm thinking about doing like a 1.5" leveling kit so it willl look a little better and level up. but i'm also thinking about getting some black cragar rims when i get the tires so idk but i'll see.
__________________
#29 (permalink) |
Rims
Check wheelers offroad for the black steelies and make sure you get the 16 inch ones because the "guaranteed" fit on 16s from his 15s isn't really true. My bro couldn't get the 15s to fit his '00 TRD that came with 15s!
__________________
#30 (permalink) |
i have a daystar 2.5 coil spacer lift on my 00 runner, the ride is nice, too nice for me, i like it to be more stiff, but i've had them for over a year, and they are still handling very well.
__________________
:2000 4Runner 2.7L 5spd 2wd :( :32x11.5x15 bfg a/t :Daystar 2.5 coil spacer body lift :front custom steel braided brake lines :herculined front and rear bumpers :HID conversion |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1.5" daystar spacer lift okay? | TRDrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 02-08-2007 03:34 PM |
| front daystar spacer from wheelers | TX2RUNNER1997 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 04-14-2006 10:44 AM |
| Lifts...solid (Cornfed) vs Plastic (Daystar) | nrgetic99 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-02-2004 05:46 AM |
| Daystar Coil Spacer questions. | JACKLEE | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-27-2003 07:02 PM |
