Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
cutting metal cover plate after body lift
I recently installed a 2" body lift, and like many others, need to make adjustments for the transfer case shifter. I think it'll be fine if I just cut some of the metal cover plate that is underneath the boots. My question is: what's the best way to cut the plate? I guess more specifically, what tool do I need?
__________________
1986 pickup 4x4 SR5, 31x10.5 BFG All-Terrains, Ranchos, 2" body lift, Downey grille guard and skid plate, TG sliders |
| Sponsored Links |
#2 (permalink) |
You should have got a shift lever extension that is welded to the shifter after it's cut. The instructions in my Performance Accesories kit mentions it. There are 2, one for each shift lever.
Is it still hitting even though you welded this in? You may have to heat and bend the shift lever. |
#3 (permalink) |
I don't think the extension would help. The metal plate is blocking me from going into 4LO because it gets in the way closer to the base of the shifter than to the top. So putting an extra 2 inches on up top wouldn't fix the problem.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| custom metal work...welding and cutting... | Yay_area_408 | The Fab Shop | 13 | 04-11-2007 08:07 PM |
| Cutting metal | drguitarum2005 | Tool Time | 16 | 12-29-2006 01:51 AM |
| Diamond Plate Sheet Metal | AaronW | The Fab Shop | 13 | 11-27-2005 07:15 PM |
