| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Counting Gears
__________________
Corey '94 3.0 5 speed |
#2 (permalink) |
4 nuts, 1 brake line on each axle and 10 or so nuts on the third, 45 minutes worth of work pop the third and count them for real. Judging 'a few degrees' is very subjective when turning a tire.
a tired 3.0 is a dog to begin with. auto or stick? 4.88's with 33's...it may not seem like a big difference numerically from 4.10 to 4.56 but a lot of people's butt dynos feel otherwise. but yes 4.88's would help get it back to stock
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#3 (permalink) |
Stick. Not too tired. I'm working on the engine. It's better than it was. Subjective, yes, but by a few degrees I mean just a few. For 4.56 it would be 90 degrees past two turns, right? So, anyhow, do I have the right idea for figuring the ratio? I'm with you on the whole 45 minutes of work to count teeth, but if my counting is correct I'm gonna say I have 4.10s. What gear ratio is going to put the RPMs vs actual speed back to what it should be? Anyone know what 4.10 vs 4.56 feels like? I don't know if 4.10s were available stock on my truck. Did PO change them to 4.10 after lifting and putting on the tires? Why wouldn't he have gone lower? I found a good site for checking gear ratios vs. tire size but I have to plug in the transmission and transfer case info. It's dark out and I just got out of the shower so that's gonna have to wait.
__________________
Corey '94 3.0 5 speed Last edited by aerocorey; 10-25-2009 at 09:52 AM. |
#4 (permalink) |
My experience
4.10 and 31s = Normal and still lacks power on hills 4.10 and 33s = On the flat it feels like 31s you notice less torque on hills and from a stop in 1st gear. 5.29 and 31s = Lots of torque, great for hills. Shifting pattern is very short and it runs 3400rpm going 65 in 5th gear which is a little high. Gas mileage is about the same on the flat and better in mountains. Your speedometer will be out about 13mph @ 65. 5.29 and 33s = Good torque for normal driving. Shift patter is a little bit longer and the rps are not as high as the 31s. It is a good mix of torque and rpm. 5.29 and 37s = Feels like 4.10 and 31s. The speedometer is a little off as it is still geared lower than 4.10 and 31s, but the 37s take more torque to turn. Basically the higher the gear the number the more torque you will have, but it will lower your max rpm. 4.56 gears are common and with 33s should feel like 4.10 and 31s, this is a common swap because you buy and change the whole differential you don't change the gears. 4.88 and 33s will be geared lower than 4.10 and 31s. This generally considered the best gear for 33s but generally requires changing the gears which costs money. If you change the gears I would go with 5.29 and 33s that way when you go to 35s-37s you are already geared for it. Speed calculator http://www.marlincrawler.com/java/getspd_calc.html In the calculator subtract 1" for tires and it should be about accurate. If you want it very accurate measure from the center of the tire to the ground and multiply by 2. Differential and transmission info, you will find transmission gears here. http://www.4crawler.com/4x4/4R_TechI...#Differentials
__________________
1990 4runner, 22re, R151, 4.7, 5.29s, E-locker front, Lock-Rite rear, 37" MTRs, 51" rears all around Trail Reviews http://www.gentryoffroad.com Toyota Factory Service Manuals http://ncttora.com/fsm/index.html |
#5 (permalink) |
That's good stuff. A little dumbed down, but I suppose you're being thorough, so I'll just say thanks for the details. Don't think I'll be going bigger than 33 (I'm not as big into tire size as I am articulation and armor), but I'm not shy about spending the right money for the right results. The truck will see hills, and I'm not a speed demon on the highway. I think I'll go 5.29.
__________________
#6 (permalink) |
you dont really need to pull the 3rd. You can count revolutions. It doesnt have to be exact, cause your chioces are 4.10 4.56 and 4.88. So its easy to tell the difference. Rotate the wheel one time and count how many times the pinion flange rotates.
To go back to stock its simple math. your speedo gear is set up for the stock tire. (see inside drivers door) Lets say the stock tire is 31" tall, and you go to 33. Thats a 6% change. Now you can recover that difference in the gears. 4.10 to 4.56 is a change of 10%. That may be just right. But honestly in my experiance 4.56 is a waste. Start at 4.88. Go 5.29 if you think you will go bigger (and if you think you will stick with the 3.0). I had 4.88 stock with 35's and the 3.0 it was ok at best. then went to 5.29's and 36's/37's and it was about the same as 4.88/35's. Then I swapped to a 3.4 and went back to 4.88's on 37's and it is GREAT (my 4runner weighs 5k+)
__________________
poop 1988 stock 4runner, v6, 5spd, soft top. 1990 fj62 stock and mint! 1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system. The build up...http://www.yotatech.com/showthread.php?t=74915 |
| Tags |
| 33s, 37s, 410, 456, 488, 529, diffs, fj62, gears, understanding |
