| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Cheap Recovery Idea?
Last edited by BackCountry4Runner; 12-26-2008 at 11:40 AM. Reason: * (or incase of winch failure) |
#2 (permalink) |
Easier to buy a smittybilt winch for $300 and just go slow...
__________________
- Brian 84 toy pickup mostly stock |
#3 (permalink) |
Even cheaper to go with the wire pull. Just throwing it out there as an option in case of winch not working (btw: I have a winch).
#4 (permalink) |
With enough reduction to overcome friction (including in the pulling system) a few people could pull a rig out by hand. But I wouldn't want to spend the time finding that much hardware, and the cost of all of it might as well have bought a winch and been done with it. But it is an interesting idea none the less
__________________
93, 22RE, 5Spd, Reg Cab, Short box, ICOM IC-V8000, Hella 500's, Cobra 75 WX ST, tool box, home-brew headache rack, extended diff breathers, basically stock but upgrading as money allows. - Firefighters, Because Police need heroes too Prepare for the worst, Hope for the best Try Geocaching |
#5 (permalink) |
^^^I don think he meant pulling out by hand. lol!^^
He is talking about using the unstuck rig to pull out stuck rig. Works great. Everybody should carry a tow strap, and that should be good enough. Snatch block and anchor is a bit over kill. I have 60k pound 4" strap, and I think you would be hard pressed to break that. Most important is that all rigs you are wheeling with have solid front and rear tow points and you'll be fine. Let me add you should always wheel with at least 1 other rig.
#6 (permalink) |
Sorry I didn't mean to say pulling by hand was the point, but that the idea was valid given the time and hardware it is possible and if on that day a winch was not an option (not available, winch failure [damn that Murphy's law]), setting up a Z drag using the truck as the pulling power will work.
Think of it as another tool for the brainbox, may never get used but a tool available as an option. Prepare for the worst hope for the best
__________________
#7 (permalink) |
Gotcha, not sure what that meant. I agree wholly. Straps always wored for us. Only the one rich kid has a winch and she usuaslly stays home. haha I mean, uh...he. No half the fun for us is tugging each other in and out through the trail and desert.
A z drag is nice though for those tight spots when a straight reverse tug isn't quite possible. |
#8 (permalink) |
That could easily happen on a tight wooded loose rain slick trail, but on that trail there are several good anchor points to choose from.
__________________
#9 (permalink) |
So much easier to just hook up a strap and pull straight. You might have to pull back off the obstacle instead of through it, but that's OK
You're generating A LOT of force here - the less stuff to break, the better!
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#10 (permalink) |
if you think your cable can handle it and you actually have the space to do that kind of thing i think it would be a good way to get somebody unstuck if you don't have a winch on any of the vehicles. its always good to have resourceful thinking like that IMHO because most of the stuff he lists is something you would own if you had a winch, so if you were in an instance where the winch were to break you would be able to use this method.
for example when my truck was stuck on a rock cliff we blew up the planetary housing and clutch lever on harry's XD9000i which then lead to my friend having to get a running start with his XJ over and over again to bump me off the rock, which eventually lead to tearing his hitch out of the unibody and destroying his liftgate. either way i think its a good idea, just make sure you use cable dampeners and stand way back because with that reduction thats a lot of torque being applied to that line...
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress. 85 pickup, 327sbc, truggy, in progress. 86 mazda b2000 street queen haha. 92 mazda B2600i 4x4 absolutely mobs. 81 ford bronco drinks gas 90 mazda mx-5 all original. when in doubt, tach it out. |
#11 (permalink) |
Using the Z drag you can control the force in a tricky situation, while a strap is very useful, the tow vehicle must have enough room for a run-up and should the stuck rig suddenly become free or the strap fail and break the tow rig will need enough room to stop, which is not always possible (trees, rocks, cliff's) when the situation allows,which is usually, I do use a strap
__________________
#12 (permalink) |
I noticed you said to use "x amount of WIRE rope"......hopefully you ARENT using a tow-strap made out of wire cable! When most vehicles are assisting in getting the stuck vehicle UN-stuck they arent as gentile as a winch is that is using the same amount type and amount of wire rope. Plus unless you have wire rope that is braided into eye's on each end, your using cable locks, which will eventually fail or cut the wire rope, and then you'll be eating through a straw for the rest of your life when the tensioned end of the wire rope comes through your windshield and pops you in the face.
__________________
SHAKE AND BAKE!!! |
#13 (permalink) |
[quote=scottapher;51008185]I noticed you said to use "x amount of WIRE rope"......hopefully you ARENT using a tow-strap made out of wire cable! When most vehicles are assisting in getting the stuck vehicle UN-stuck they arent as gentile as a winch is that is using the same amount type and amount of wire rope.QUOTE]
Hey, no, I do have a tug strap, but wire rope(cable) from a defunct winch can be used, and in the 2:1 or 3:1 pulls I wouldn't think that anyone would put it into 4Hi and gun it. More of an easy 4Lo kind of application. Also, whenever pulling, winching, or whatevering, saftey measures such as dampeners on the lines and a clear work area should be used. It sucks having a stuck rig. It sucks even more having a stuck rig & injured people. |
#14 (permalink) | |
Quote:
Also with a winch, you can recover yourself.
__________________
'85 Xtra Cab Knobbly tires and such things. |
#15 (permalink) | |||
Quote:
i've seen this in action on dirty jobs, army edition. they pulled out a stuck humvee by using a bunch of snatch blocks and 6 guys
__________________
Olive Drab 1995 4WD regular cab pickup,22re, 33x10.5 BFGs,doetsch tech prerunner shocks, all pro shackles,sway bar delete. Quote:
Quote:
TREAD LIGHTLY |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Theft Recovery Idea | Kaleb | General Electrical & Lighting Related Topics | 136 | 08-13-2009 03:33 PM |
| Simple, cheap, heavy duty bumper idea | navyredneck | The Fab Shop | 20 | 03-10-2008 11:40 PM |
| Good idea? Bad idea? Cheap Blower intake. | YotaTruck1986 | 95.5-2004 Tacomas & 96-2002 4Runners | 29 | 01-16-2008 08:24 PM |
| Super-cheap air tank idea.... | chimmike | Offroad Tech | 27 | 02-09-2007 09:11 PM |
| My cheap lift idea | fo_runner | Offroad Tech | 7 | 12-13-2005 05:25 PM |
