Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
can i shorten my own d shaft?
i had a d shaft lenghtened after my sas but i changed the springs to something a little lower in the front this past weekend.now i need about 1.5 inches taken out of this shaft.can i do this myself?i have acess to a machine shop and a welder but i donmt think i can fit the shaft tube in our lathe.
| Sponsored Links |
#2 (permalink) | |
You will need to machine off the weld, then shorten the tube, and reweld the assy.
If you have never done it before, just take it to a shop. Its pretty cheap insurance not to break it on the trail.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts! Quote:
#3 (permalink) |
if i cut the tube to the length i need then i can chuck it on the splined end and machine it off.
#4 (permalink) | |
Just make sure the cut is exactly straight, otherwise your driveline will wobble. You also need to find a way to balance the shaft, so you don't have vibration issues.
__________________
#5 (permalink) |
i posted this at lunchtime and now its breaktime at work.ive already got it done.i dont know how straight it is but it pressed in tight so im assuming its good.its a front shaft anyways
#6 (permalink) |
I would have recommended you just cut off the splines so it will compress further.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#7 (permalink) |
ok i knew this all went together too easy.
i just put the slipyoke on and tried to align it(phasing i think its called)i cant get it perfectly lined up with the fixed yoke at the other end.its very close.is this gonna give me problems?i guess i should have put the slipyoke on the splined end and then pressed it together. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| steering shaft | sleaz22xx | 86-95 Trucks & 4Runners | 9 | 06-18-2008 03:25 PM |
| shorten tie rod ends for 4" ifs lift? | 89-4Runner | 86-95 Trucks & 4Runners | 2 | 04-17-2006 05:02 PM |
| Can Coil Springs Be Cut To Shorten? | Gerdo | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 04-11-2006 04:36 PM |
| CV shaft removal | JPW0504 | 86-95 Trucks & 4Runners | 12 | 03-29-2006 07:57 AM |
| Shorten the antenna? | Col. Mustard | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 05-12-2004 12:32 PM |
