A/c to onboard air question. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-16-2005, 03:30 PM   #1 (permalink)
wimpywade94's Avatar
Hello, just wondering if anyone could tell me how excactly to attach a quick disconnect hose onto an air compressor.
or lead me in the direction of a website to tell me how to do it,
thanks
wade
__________________
86 runner, rebuilt motor, egr block off, headman header, 3"bl, 33x12.5 m/t's. Lots of work wanted to do. limited skills, funds, time and drive.
If you dont know where your going, anyplace will do.....
wimpywade94 is offline
Old 10-16-2005, 03:49 PM   #2 (permalink)
gummi's Avatar
Send a message via AIM to gummi Send a message via MSN to gummi
What are you trying to do ?
I have A/C air, connected to a tank and a sensor for turning off the compressor when it's full.
__________________
1992 Toyota Hilux Double Cab
38" Ground Hawk II. Rear axle moved 15cm, 4-Link (springs)
GPS,VHF,CB,A/C compressor,ARB locker, 2.5" exhaust, exhaust headers. Second Gas Tank. 5.71 Diff-Ratio
My website
gummi is offline
Old 10-16-2005, 04:11 PM   #3 (permalink)
4Crawler's Avatar
Just get one of these and attach it to your air system, to the tank, to the end of a hose, etc.:
More info: http://www.4crawler.com/4x4/ForSale/4air.shtml#Chucks
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-16-2005, 04:23 PM   #4 (permalink)
gummi's Avatar
I would..
... get a tank and connect the AC to the tank.. then lead a hose from the tank and have the quick disconnect there..
less chance of blowing a hose, more air when you need it etc..
__________________
My website
gummi is offline
Old 10-16-2005, 04:35 PM   #5 (permalink)
how should i go about connecting the ac to the tank though.
wade
__________________
Old 10-16-2005, 04:42 PM   #6 (permalink)
gummi's Avatar
just a hose that can handle the pressure..
... and you need to find a good tank / cylinder.
On mine the AC sucks air from the air cleaner box, then on the out air hose it's connected to a air / oil seperator, and a thin hose cycles the oil back to the intake for the AC. Afther that you can do whatever you want, I would route the air to the tank. Then from the tank I would run a hose to a sensor, that will cut the power for the AC off at 100psi. then you can have a other hoses connected to that for whatever you'd like to do with the air.. I use it for both the locker and a quick connect mounted on the rear of the truck for pumping the tires.
__________________
My website
gummi is offline
Old 10-16-2005, 06:30 PM   #7 (permalink)
4Crawler's Avatar
Quote:
wade
Get one of these kits:
http://www.frontrangeoffroadfab.com/manifold.htm
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
got my onboard air done INFINITY Offroad Tech 10 06-17-2007 11:50 AM
Onboard Air-Compressor Mount dragr1 95.5-2004 Tacomas & 96-2002 4Runners 12 12-24-2006 07:37 AM
Do-it-yourself onboard air Robinhood150 Off Road Enhancements 0 01-07-2006 07:46 PM
a/c to onboard air help forty4 Offroad Tech 2 11-13-2004 03:34 PM
onboard air or winch? jacksonpt 95.5-2004 Tacomas & 96-2002 4Runners 6 04-06-2004 11:16 AM
2009 InternetBrands, Inc.
