| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Bumper recovery point?
#2 (permalink) |
Staff
A bumper should never be used as a recovery attachment point because of the potential forces involved the frame is the preferred area. That being said for a lightly stuck vehicle [not deep mud/river bed/ deep ditch] the bumper might be used as a point of last resort.
If your bumper was attached with the factory bolts they are the metric = of grade 8 and are plenty strong enough, the bumper itself is the weak point. If you use the ball attachment holes you may experience some tear-out issues. Make sure that no one is standing where they may be hit should the shackle rip out and warn the other driver to keep an eye on the line... they may have to duck quickly if it come through their windshield. Avoid jerking and apply a slow steady strain on the line and you may be able to make it work. You can get shackles from trail gear. Check out the linky below member tofer is a dealer and is running an excellent fund raising promotion for1972TLC who was in a serious auto accident shortly before christmas. http://www.yotatech.com/f5/help-1972.../#post51009848
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. |
#3 (permalink) |
I would not use a bumper like that for a recovery point. If you have it attached with grade 8 SAE or 10.9 Metric, they will probably hold. The next question is how well are the mounting tabs mounted to the actual bumper? I have seen alot of that type bumper pushed of center, the mounting tabs bent. They don't look like that have much lateral strength. A good yank to the side and I would think the bumper mounts will bend. NEVER wrap a strap around a bumper like that. The raw sharp edges will cut through the strap.
I would get a couple of good recovery points mounted to the frame with good bolts. Do you have any in front?
__________________
2000 4Runner Sport, 3.4L, 5 Speed, Custom Front Winch Bumper, Opened intake, K&N Airfilter, BFG A/T LT265/70R16, Bilstein Shocks, FreeFlow Exhaust, Poly Rack Mounts & Swaybar Mounts, Tundra TRDs up front and OME 891s out back. ToyTec Panhard Bar Drop. SS Front Diff Drop. Home-built 2x2 Sliders. ARB rear locker, OBA, CO2 See My 4Runner! |
#4 (permalink) |
Thanks for the replies guys.
Gerdo - I do have the stock hook out front. Should there be a hook or something out back? If not is there something you would recommend buying to bolt up underneath? |
#5 (permalink) |
the stock hook and d ding are not rated. but you could get some shakle's or hooks that are rated with the proper hardware of course.
__________________
1989 Toyota Hilux Double Cab |
#6 (permalink) |
has anyone ever had a problem with the factory hooks bending or snapping? im not being a smartass im really curious. i just added 2 factory hooks to my truck because the 2wds only come with the skinny loops and you can bend by looking at them wrong.
__________________
94 pickup: Std Cab, 22RE, 5spd, 2wd Front: Total Chaos Uniball Kit, Downey Torsions, Fox 2.0 8'' Reservoir Shocks, Hannemann Fiberglass Fenders Last edited by Robert m; 12-27-2008 at 10:15 PM. |
#7 (permalink) | ||
i would never use my stock bumper as a tow point, very unsafe.
__________________
Olive Drab 1995 4WD regular cab pickup,22re, 33x10.5 BFGs,doetsch tech prerunner shocks, all pro shackles,sway bar delete. Quote:
Quote:
TREAD LIGHTLY |
#8 (permalink) |
Not really. My frame was so rusted up front that the frame tweaked a bit and the bolt bent, but never an issue with the hook itself.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
| Tags |
| 04, 4runner, 87, arb, ball, bumper, colorado, hook, point, points, recovery, ring, stock, tabs, tow, towing, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| D-ring shackle through stock bumper hole for recovery purposes? | BAZ | 86-95 Trucks & 4Runners | 19 | 05-31-2008 02:09 PM |
| Custom Rear Recovery Point | 881stGenRunner | Offroad Tech | 9 | 06-06-2007 11:49 AM |
| Rear Recovery Points without aftermarket bumper | EWAYota | 86-95 Trucks & 4Runners | 20 | 03-02-2007 07:21 AM |
| Tow Ball Hitch as Recovery Point? | ORB | Offroad Tech | 7 | 04-02-2005 05:38 PM |
| Safe Recovery Point | jimrockford | Offroad Tech | 5 | 09-23-2003 06:13 PM |
