| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
00 4RUNNER SR5 2WD 02 TURBO Altima 3.5 04 YAMAHA R1 Check out my CarDomain for the 4RUNNER Check out my CarDomain for the Altima |
#3 (permalink) |
BEFORE
![]() ![]() 1” BODY LIFT ![]() ![]() AFTER ![]() ![]()
__________________
00 4RUNNER SR5 2WD 02 TURBO Altima 3.5 04 YAMAHA R1 Check out my CarDomain for the 4RUNNER Check out my CarDomain for the Altima Last edited by Guerrero; 04-25-2005 at 05:15 PM. |
#4 (permalink) |
Sponsoring Vendor
Looks great!
__________________
Phil Toyota & TRD Parts Wholesale www.FJCruiserOffroad.com www.trdparts4u.com www.toyotapartsales.com Authorized ARB/OldManEmu Dealer Authorized OASIS Air Deflators Dealer |
#5 (permalink) |
If I re-gear my rig, what are the new gears I have to go with? 4.88?
I’m not sure what gears I got now, but I think I have a 3.3 / 3.42 gears. My Vin plate A/TM #s: A01A/A340E Do I need a PanHard Drop and Parking Brake Bracket? What is the speed rating for the BFGoodrich Mud Terrains? I need to do an aligment, but before I go to any shop, where should I take it? I'm in San Diego. My tires are rubbing against the Upper A-Arm. I guess, I can shave them a little, but if I do that, am I going to have any problems? ![]()
__________________
00 4RUNNER SR5 2WD 02 TURBO Altima 3.5 04 YAMAHA R1 Check out my CarDomain for the 4RUNNER Check out my CarDomain for the Altima Last edited by Guerrero; 04-25-2005 at 05:16 PM. |
#6 (permalink) |
Hmm... can't see the pics
__________________
97 4Runner SR5 Blue - 135k miles, E-Locker, Armorology front/rear bumpers & sliders, BudBuilt skidplate+belly, MTR 285/75/16s, 2" Tundra/OME Lift, 1" 4Crawler Bodylift, 1" diff drop, Black Aluminum Wheels, Cobra CB 04 Land Cruiser Grey - 90k miles, OME Lift, Slee Sliders, 35" Toyo Muds |
#7 (permalink) |
i can't either.
#8 (permalink) |
How can I post pictures?
I used [IMG]link[/IMG], but I just got the links. The pics are hosted in my pictures\yahoo
__________________
00 4RUNNER SR5 2WD 02 TURBO Altima 3.5 04 YAMAHA R1 Check out my CarDomain for the 4RUNNER Check out my CarDomain for the Altima Last edited by Guerrero; 04-25-2005 at 03:37 PM. |
#9 (permalink) |
Well I'm not sure how yahoo works, but your links are not direct links to image files (.jpg). There seems to be some kind of php stuff going on
__________________
#10 (permalink) | |
Quote:
Lookin' good from what I can see though.
__________________
2002 4runner |
#11 (permalink) |
pics not workin' for me..i really wana see!!
__________________
REDrum |
#12 (permalink) |
try posting them in www.imageshack.ws
__________________
2000 4Runner Limited 3.4L 4wd, Factory Locker, 265/75/R16 BFG AT KO's, Surco Roof Rack w/ 4 IPF Fogs, 2 Hella 500's up front Wish list: Tundra/OME lift-TJM T-15 |
#13 (permalink) |
not working for me either.
#14 (permalink) | |
Quote:
Thanks
__________________
#15 (permalink) | |
Quote:
Speed rating, look up on the tire sidewall to find out: http://www.4crawler.com/Diesel/Tires.shtml#SpeedRating Tire rubbing, a wheel spacer 3/16" to 1/4" would fix that as well. For new gears, to restore to stock effective gearing, take new-tire-size / stock-tire-size * stock-gearing = new-gearing.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 04-25-2005 at 05:51 PM. |
#16 (permalink) |
pix work for me, looks great! follow rogers link and get ready for a few more dollars to disappear from your wallet! if you decide to change wheels you can get them with the correct back spacing to eliminate the rubbing issue with the 'a' arm. 4crawler.com has a pretty comprehensive site with lots of info, dig around and you will find more info on just about anything you could want to do!
lee
__________________
93 sr5 v6 auto, 4x4 Photos http://s866.photobucket.com/albums/a...albumview=grid there are quite some attractive ladies on here with Toys. (compliments of ironmike) ifsc 3(.0) http://tlca.org www.of4wd.com www.sontt.com |
#17 (permalink) |
looks great, just needs some mud now
__________________
#18 (permalink) |
I have the same problem with the a-arm rubbing, I grinding some of it down, but it still get REALLY close when I flex. And that's without airing down.
So I'm probably gonna go with 1" wheel spacers. Just make sure you get the one with studs, no slip on spacers. looks hot.
__________________
Rob |
#19 (permalink) |
Front bumper installation pics
I have to trim the a piece of the outter bumper bracket to be able to bolt the bumper
I have to cut I little piece of the stock bracket to be able to fit the bolt that is going to hold the outter bumper Only the bottom two bolts are holding the inner bumper
__________________
#20 (permalink) |
looks good, nice job
#21 (permalink) |
Still haven't figure it out what's the speed rating for the tires:
here is what the sidewall has: LT285/75R16 122/119 Q M+S Q= 99 miles per hour M= 81 miles per hour S=112 miles per hour Before the lift I used to drive between 80/90 (flow of the traffic), now I haven't past 70
__________________
#22 (permalink) |
Sponsoring Vendor
Q is the speed rating. The M+S is Mud + Snow rated.
__________________
#23 (permalink) |
you'll want to go to 4.56 gears w/ the 285's on there.
you can get yukon for the rear, and you don't have to worry about the front since you're 2WD. expect to pay about $250-$300 for the gears and master install kit, then another $100-$250 in labor to put them in depending on how much work you do and how much the shop does... looks good! |
#24 (permalink) |
^^^Thanks
I need to do an aligment, but before I go to any shop, where should I take it? I'm in San Diego. Do I need a PanHard Drop?
__________________
#25 (permalink) |
Sponsoring Vendor
I just did the Pan Hard drop and got an alignment. What a difference it made. I would recommend it with any lift 2" or more.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How can I tell if my 4runner has a suspension or a body lift. | Lifted96 | 95.5-2004 Tacomas & 96-2002 4Runners | 23 | 08-03-2007 11:51 AM |
| Body and suspension lift are done | Guerrero | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 04-25-2005 04:20 PM |
| lift body or suspension | MellamoPOUND | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 10-09-2003 01:50 PM |
| Body & Suspension Lift | Cmar | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 09-26-2003 03:14 PM |
| body vs suspension lift | decepticon | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 09-24-2002 09:34 AM |
