biggest tires?
biggest tires?
what would you guys say are the biggest mud tires i could put in a stock 93 4x4? i have 31/10.50's right now, but they are all weather tires.
Ok, so, before we get any further, the search function will help you out. This is probably THE most common question this board gets.
Now, your question:
It depends on whether you want to lift or not. I had a 90 4x4 not too long ago. 32x11.50's will fit with some rubbing, but 33x10.50's will fit quite well, a bit of rubbing, but you get to use the stock rims. If you lift it, 33x12.50's will fit just fine. 35's with a body lift. Keep in mind that an 11.5 inch wide tire it is suggested that you get new wheels, and 12.5 inches wide, it's a must. I wouldn't suggest going over 35's though, the stock IFS doesn't really like that.
Now, your question:
but what about the suspension and stuff. i already have alloy wheels, but i don't plan on a lift or changing axels or anything like that. i just want to put the biggest tires that will fit without any modifications.
Stock: 32x11.50's will fit with some rubbing, but 33x10.50's will fit quite well, a bit of rubbing, but you get to use the stock rims.
Anyways, I run the metric equivalent to 33x10.50's. I don't have a lift, and I was able to use the stock wheels. They do rub a touch, nothing bad though.
Here's a great article to read that talks about the benifits of tall narrow tiresL http://www.expeditionswest.com/resea...tion_rev1.html
djpg2000
11-11-2020 04:56 AM
