YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
View Poll Results: What transmission do you all prefer while wheeling?
Manual 66 61.11%
Automatic 42 38.89%
Voters: 108. You may not vote on this poll
Thread Tools Search this Thread Display Modes
Old 06-16-2008, 06:46 PM   #1 (permalink)
SpecialScottie's Avatar
Auto or manual
Any specific reasons?
__________________
1st gen 4runner interior for sale here
87 Turbo 4runner STOCK
85 4runner Build Thread
87 4runner (parts)
95 4runner 2wd auto
SpecialScottie is offline
Sponsored Links
To remove this ad, register today!
Old 06-16-2008, 08:33 PM   #2 (permalink)
4rnnr33's Avatar
manual for sure there is no way i would ever buy a toyota that is an automatic. and btw this has been covered tons of times
__________________
95 4runner, 5 in tg sas and rear leaf swap, chopped, mx6 reservoir shocks, 35x13.50x15 toyo mt's, all pro front bumper, mile marker se9500c, rear tube bumper, hella 500's, rock lights, optima red top, glass fenders, tg 5.29's, lockright rear, detroit hp front
4rnnr33 is offline
Old 06-16-2008, 08:33 PM   #3 (permalink)
crolison's Avatar
manual, i know what gear i am in all the time, and can control when it shifts. If i need to go faster in 4lo just shift to 3rd or 4th.
__________________
97 4runner, 2.7 5speed 4wd, 4.556, 255/85/16 Maxxis Bighorns
rear diff breather, 4 hella 500's driving, sliders, wilderness rack
custom bumper
arb locked rear
toytec adjustables, ome 891's, bilstein 5125
manual hubs
broken front and rear swaybars
My Profile
crolison is offline
Old 06-16-2008, 08:39 PM   #4 (permalink)
Hayes's Avatar
Send a message via AIM to Hayes
automatic, lots more control only having to deal with 2 pedals, plus there is less shock to the driveline.
And TC, I am going to beat you to the punch. That is my opinion and you aren't going to change it!
__________________
-Hayes
Hayes is offline
Old 06-16-2008, 10:24 PM   #5 (permalink)
tc
tc's Avatar
Manual with a crawler FTW, but that's not really a choice ...
Here's the deal - the overdrive in the pre-Tacoma trucks is HORRIBLY matched to the engines. You need to gear AT LEAST 2 steps lower with the auto than the manual if you plan to drive it to the trails, and that limits you in all reality to 33's which kinda sucks.
Hayes has the positives of an auto listed above, and he's right ... what he's leaving out is the minimal (if any) compression braking, the unpredictability of when the torque converter will engage, the lack of ability to start in a gear other than first when wheelspeed is required, and the vast reduction in options for when something breaks.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 06-16-2008, 10:39 PM   #6 (permalink)
Hmmm sounds about 50:50
I have the auto in my turbo runner and im deciding if I want to go through all the effort of putting a manual in it
Ohh and thanks for all the help guys
__________________
87 4runner (parts)
95 4runner 2wd auto
Old 06-16-2008, 11:47 PM   #7 (permalink)
Kaleb's Avatar
Send a message via AIM to Kaleb
Manual. Before I swapped to a manual I was crawling up a large log in 4 low. When I started to reach the top of the log I knew it was two high and I needed to come down, so I stepped on the brakes but didn't stop. The torque from the low gear range powered right through my brakes... Luckily my buddy jumped on my left side door too keep my runner from rolling. Now to avoid this problem I can simply press the clutch and disconnect the drive train.
__________________
1994 Toyota 4Runner
V6 3.0
5 Speed Conversion
Solid Axle Swap
Rear Leaf Spring Conversion
1985 Solid Front Axle
Bilstein 5150's All Around
35" BFG Mud Terrains
Yukon Full Spool in Rear
3" Exhaust w/ Hi-Flo Cat and Magnaflow Muffler
Drilled Air Box
MY BUILD
Quote:
Originally Posted by Big_Denny View Post
i have been trying to find the dip stick for my rear differintial and just can not fid it is there a posibilty that the previous owner removed it? or lost it? he seemed pretty dumb and didn't know about wheeling
Kaleb is offline
Old 06-17-2008, 12:25 AM   #8 (permalink)
stormin94's Avatar
Manual all the way. More power, more MPG, more control, and No you don't have to shift all the time. Just when YOU want to, not when your car wants to.
__________________
1994 Toyota 4Runner SR5 4X4
208,000 miles and counting
3.0 V6, 5 speed
14/19 MPG city/hwy(before 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 06-17-2008, 12:46 PM   #9 (permalink)
4rnr's Avatar
Auto. Just as all the pro rockcrawler why they dont use manuals
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, custom snorkle, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Electronic shifters by AWshifting, Mcintosh/Dynaudio a/v system.
The build up...http://www.yotatech.com/showthread.php?t=74915
4rnr is offline
Old 06-17-2008, 01:25 PM   #10 (permalink)
AxleIke's Avatar
I'm with TC.
Manual with a crawler.
All the control you could ever possibly want, literally next to impossible to stall, and all the advantages of the stick. In double low, I never need to clutch anything.
Nothing against auto's personally. They work well too. I just like my stuff.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 06-17-2008, 03:41 PM   #11 (permalink)
Team420's Avatar
I have both, in my runners, and I have to say...they both have advantages, and disadvantages....example... a very steep hill in the sand pit behind my house, the 5 spd stalls halfway up in 4hi, the auto went almost to the top before it started spinning...also in 4hi... on the trail, the 5spd seems to have a bit more control, also when climbing rocks...but for mud...I prefer the auto all the way...no need to shift or clutch...thus loosing speed, and traction, with the auto, you just give her some!! Hope that helps....o and btw...the auto gets avg, 14-17mpg, while the 5spd gets 20+ mpg, and has waaaay more power.
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock.
It's becoming an addiction.
Team420 is offline
Old 06-17-2008, 03:43 PM   #12 (permalink)
Team420's Avatar
O yeah...just thought of another disadvantage to the auto...see avatar....that cost me over $100 in tranny fluid...if it were a 5spd...no prob!
__________________
DD:
Project:
Team420 is offline
Old 06-17-2008, 03:51 PM   #13 (permalink)
crews462's Avatar
No question a manual, i agree i wouldn't drive an auto truck, unless the price was too hard to pass up on.
__________________
89 Pickup, 22RE, 5 spd, 175XXX
crews462 is offline
Old 06-17-2008, 05:07 PM   #14 (permalink)
Thanks all for the responses.
I got a real good deal on my turbo and as many of you know they only come in auto.
Im looking to get some larget tires and the power of the 5 speed would be nice on the street.
How big of a job is it to do a tranny swap?
__________________
87 4runner (parts)
95 4runner 2wd auto
Old 06-17-2008, 06:58 PM   #15 (permalink)
Hayes's Avatar
when you swap the manual, let me know how much you want for your auto
__________________
-Hayes
Hayes is offline
Old 06-18-2008, 10:50 AM   #16 (permalink)
Gene's Avatar
Send a message via Skype™ to Gene
I have had both. The manual gave better control when crawling but in a hill climb/mud/street, give me an auto!
__________________
DREAD
2004 TRD SR5 Double-cab Tacoma
Toyo Open Country M/T 265/75/16
Fabtech 3.5" lift
Snugtop XTR Shell
http://www.wattora.com
http://www.genehobbs.com
Gene is offline
Old 06-18-2008, 02:40 PM   #17 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
I'm going to swap my truck to an auto soon. Will be using an A343F from a 3.0TD Hilux Surf so it must be a very direct swap. As it is a electronic controlled tranny and my engine (1KZ-T) has no ECU (Like a carbed) I'm going to use an universal auto tranny controller from Powertrain Control Solutions. I've only to add a TPS and I'll be ready to go, being able to configure ALL the settings and also drive it in manual sequential mode with paddle shifters (Probably adding two switches in the steering wheel).
Also, as it's a diesel and it can run in 3rd high at idle without stalling, I'm sticking with the chain driven T-Case for the moment, will think on duals if I won the lottery.
Anyways I'm anxious to test the truck in the sand dunes of the Sahara Desert...
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write...
Blizzard is offline
Old 06-18-2008, 05:05 PM   #18 (permalink)
TC4RNR's Avatar
if you are planning on wheel a lot of sand dunes, go auto. down shift in the middle of incline can get you stuck all the time. Auto, on the other hand, has better handling on that. (maybe i need to learn how to drive, but for now, that's MHO.
i'm a manual guy, for me, it's just more fun with a 5 spd, period.
__________________
http://i172.photobucket.com/albums/w...gca/agreed.jpg
94 4Runner, SR5 3.0V6, 4WD, 5spd: SOLD
99 4Runner, SR5, 3.4L 4WD, 5spd. 265/75/16 BFG A/T. full SS 1.2 lift, RedLine Fluids, Marlin 1200 Clutch, ARB front bumper, BruceTS rear bumper, roof busket, hitch mount tire carrier, Tundra Brakes, Brembo rotors, BudBuilt skid/belly, Lightforce 240 Blitz, PiAA HID, Stubb's HD-SKO sliders.
TC4RNR is offline
Old 06-18-2008, 09:55 PM   #19 (permalink)
JamesD's Avatar
Could your edit your post for a poll? This would make it easier.
Thanks, James
__________________
2nd gen power mirrors for sale http://www.yotatech.com/f109/2nd-gen.../#post50746877
New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569
Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/
JamesD is offline
Old 06-18-2008, 11:26 PM   #20 (permalink)
Id love to but im actually not sure how?
Help please?
__________________
87 4runner (parts)
95 4runner 2wd auto
