| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Air tank possibility?
#2 (permalink) |
........ ......... No idea, but I'll let u see the power of my CO2 tank at pismo
__________________
Milton 01 Tacoma access cab 4x4 TRD TC Long travel, Supercharged 04 Tacoma Doublecab 4x4 TRD hoes all around! |
#4 (permalink) |
yeah it will work, just get bushings to fit to the size of hose you need, just dont go over 100 psi
__________________
91 4runner sr5 Co-founder Boat Drinks Off Road Some odds and ends mods tatooed white trash bumper sticker |
#5 (permalink) |
Hmmm... interesting.
![]() Wow. Too many mods to keep up with
#6 (permalink) |
You can get a 135psi, 5 gal tank from Sears for $16.
http://www.sears.com/sr/javasr/produ...id=00915200000
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
#7 (permalink) |
Can you refill/recharge it though?
I was thinking more in terms of something like the fire extinguisher -> air tank mod you have on your site. Last edited by Tacoma Dude; 05-30-2004 at 09:57 PM. |
#8 (permalink) |
does it even hold CO2 steve?
__________________
95 4Runner SR5 3.0l. V6 2 wheel drive baby! 31" Bridgeston Dueler A/T Revos. Downey 1.5 Coils. Doetsch MV-12 Shocks. Brembo Rotors. Performance Friction Pads. Pioneer head unit with 1 12" Pioneer woofer. XM Radio. RB Headlight Harness w/ Sylvania SilverStars New to the family: 85 4Runner 22RE, 4x4, 5 spd, SFA. 31" BFG All Terrain T/A KOs, genuine Walmart seat covers, "Dual" stereo, XM Radio, RB Headlight Harness w/ Sylvania SilverStars. Onboard air. Has been seafoamed to hell |
#9 (permalink) |
Of course you can refill it, how are you going to get air in there in the first place?
You still need a compressor and the tank alone isn't going to be enough for pismo. No Co2, but neither can the one peter posted about.
__________________
#10 (permalink) |
I may end up going with the eyewash tank... the Craftsman is a bit on the small side and the larger 10 gallon tank is over $35. The eyewash tank is a bit more than 10...
...then again, 135 psi vs 100 psi limitation. Hmmmm. |
#11 (permalink) |
What are you going to use to fill it? You still need a compressor.
$5 off coupon at sears: https://www.citibank.com/us/cards/sv...s/sears-b1.htm
__________________
#12 (permalink) |
I picked up 2 caddy compressors a few months ago. Hadn't figured out where I was going to put them. I think I know now so I'm starting to plan
![]() Thanks for the coupon though, I might end up using that for something else
#13 (permalink) |
My caddies have a hard time over 100psi, especially now that I've used them hard. The 100psi limit on the tank should be ok.
But...what pressure is that tank normally used at? It's pressure tested to 100psi, but does that mean it can handle 100psi continuous? I don't know.
__________________
#14 (permalink) |
Well, it's an eyewash tank - these things aren't used very frequently so I'd assume that it wouldn't have a problem staying at 100 psi.
#15 (permalink) |
Here's how the website describes it:
Portable Eye Washes/Drench Hoses Easy-to-operate push plate with stay-open valve activates steady flow of water for 15 minutes of flushing. Specifications: Combination Eye Wash/Spot Drench Hose has a 10-gallon, Type 304 stainless steel tank (8-gal. functional capacity). Relief valve and pressure gauge prevent vessel over-pressurization. Spray head assembly slides into a socket on top of the unit for storage or hands-free eye and face washing. 8'L flex-coil hose allows spray head assembly to be lifted to direct water at other areas of the body. Can be pressurized by bottled or plant air. 25"H x 12-1/4"O.D. Choose Heated Combination Eye Wash/Spot Drench Hose unit for indoor or outdoor use. Heating element is a band heater with thermostatic control that maintains water temperature between 60°-90°F. Eye Wash and Drench Hose have the same specifications as the combination units except the eye wash and drench hose are separate. All units include water treatment additive. • Flow Rate at 100 psi: Eye Wash: 0.4 gpm, Drench Hose: 0.4 gpm. Compliance: ANSI Z358.1-1998. SEI certified. What do you think, Steve? |
#16 (permalink) |
An old propane tank would hold more pressure. I've got a few laying around that dont have that pressure valve so they cant be refilled. I'm think about converting them to air.
#17 (permalink) | |
Quote:
You'd have to do revalving and I think (not worth much) that it will be a lot of extra trouble. Better to get something made for the job. Get this
__________________
4Runner Anthracite 98 LTD 3.4 AT 205K miles, 285 Pro Comp X-Treme MT , Blue Taco Shocks and TRD tundra coils, Diff Drop, N86 and 891 w/ cones, 1.5" Body Lift, E-Locker w/anytime mod, 4 in. Deckplate, Amsoil air filter and fluids, Optima 34R, Yak Rack and Hull Raiser. (Wrecked 94 is still missed)-----See the pics----- Last edited by Mossback74; 05-31-2004 at 04:13 AM. |
#18 (permalink) |
Revalving for output, right?
I hadn't thought of that. I'd have to go back and see what the get-up was like again. |
#19 (permalink) |
When I look at that thing, beer comes to mind.
Gadget |
#20 (permalink) | |
Quote:
__________________
#21 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#22 (permalink) | |
Quote:
I have a lot of space under my rig from where my spare *used* to be. Maybe I'll just go with a smaller tank and place it down there
#23 (permalink) |
Guest
IMHO, if you already had the eye-wash tank (as in "free")...then it would be worthwhile to save some dough. I just don't see much cost benefit.
Anywho, good luck on the OBA setup. ![]() Jim |
#24 (permalink) |
Staff
Reading all this stuff about on-board air is making me want to get a setup in my truck.
What would be a good complete setup (air-tank, compressor, etc..) for a beginner wheeler...I don't need anything too expensive or high-tech, just something that could fill up a 33" tire pretty quickly. And something that wouldn't take up too much space would be nice too. Sorry to hijack Peter... Fink
__________________
1985 4Runner 22RE 4WD "Ratchet" 2007 Tacoma Double Cab SB 4x4 V6 TRD Sport AR-TTORA "My work number is 9-1-1." |
#25 (permalink) |
Something else I forgot to ask is the thickness. If it is to thin, It could puncture very easily. Just something to think about.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Make your own air tank? | getitdone | The Fab Shop | 6 | 10-15-2007 02:38 PM |
| What size air tank? | Albuquerque Jim | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 08-24-2005 09:22 PM |
| Air Tank? | nees1212 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 07-13-2004 12:45 PM |
| Air tank for on board air | mtnbkr | Offroad Tech | 2 | 05-05-2004 06:42 PM |
| 7 Gallon Air Tank | jimrockford | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 12-09-2003 07:57 PM |
