Aftermarket rear springs? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-15-2004, 02:18 PM   #1 (permalink)
YotaPagota's Avatar
I have a '99 Taco and was wondering if anyone has any ideas on replacing/upgrading my stock rear springs. I might consider a small lift and would like something that gives me decent road and off road handling. Currently when cornering it feels like its going to roll over (and looks like its going over too) and just about any bump I go over I am on the rubber stops.
YotaPagota is offline
Old 07-15-2004, 03:04 PM   #2 (permalink)
mt_goat's Avatar
Quote:
These guys make the best custom leaf springs going IMHO and just happen to be in your state. http://www.alcanspring.com/
Another much cheaper option would be to install cross-linked air shocks and then unlink them on-road. This works much like a sway bar for the rear and can be used to raise the back end too. You can get up to 2" of lift at about 110 psi in an empty bed. You can vary the pressure from 25 psi to 150 psi.
I have done both, the Alcan springs were about $450 for a pair and the air shocks were about $60/pair
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is online now
Old 07-15-2004, 06:27 PM   #3 (permalink)
NCSU-4runner's Avatar
Send a message via AIM to NCSU-4runner
http://www.allprooffroad.com/tacoma.htm
i've bought tons of all-pro stuff, never been disappointed. Pretty good pricing on some products too.
__________________
Jeremy,
94 4Runner Turbo
Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap
My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum
One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first.
NCSU-4runner is offline
Old 07-16-2004, 01:37 AM   #4 (permalink)
calamaridog's Avatar
If you are upgrading the rear springs you may want to upgrade the front also, otherwise, you may continue to have funny handling. They should compliment each other.
I highly recommend you call these guys. A.O.R., right there in CO. Talk to Randy or Kevin and they will tell you everything you need to know about springs. They can get you set-up. These guys are a class act.
http://www.aor4x4.com/index.htm
__________________
2000 UZJ100 Land Cruiser
2" OME and 33" Geolander AT's
Blue Ribbon Coalition
Toyota Land Cruiser Association
calamaridog is offline
Old 07-16-2004, 05:24 AM   #5 (permalink)
mt_goat's Avatar
BTW, AOR uses Alcan springs to make their spring packs.
__________________
~Dale~
Old 07-16-2004, 02:49 PM   #6 (permalink)
Quote:
This is correct. Which is why their stuff is so good. But you don't get their expert toyota advice and support if you buy directly from Alcan.
__________________
Old 07-16-2004, 03:56 PM   #7 (permalink)
crawler#976's Avatar
check out Deaver Springs
http://www.desertcommunication.net/deaverspring.html
One of best spring makers for desert racing-
...............I highly recommend you call these guys. A.O.R., right there in CO. Talk to Randy or Kevin and they will tell you everything you need to know about springs. They can get you set-up. These guys are a class act.
I don't ordinarily post negatives about vendors, but-
couple of things about AOR-
1. They charge your credit card when you order, not when your product is shipped. Bad Plan- your stuck, at their mercy.
2. The customer service ended after the card was charged.
3. I ordered products from them twice. The first were tube doors- nice product, well made. It took 3 months to get'm, I'd been told it would be about 6 to 8 weeks up front. The second were 1.5" steel wheel spacers. They assured me they would be shipped in 2 weeks. I waited 85 days for delivery. They would not respond to phone calls, e-mails or registered letters. In this case, they only responded to me after the charge had been placed in dispute with my VISA card holders service, and was in the process of being reversed from their account. By some minor mirical, my wheel spacers showed up on the 90th day. Most credit cards will not allow a charge reversal to be processed after 90 days, I had placed the order in dispute on the 86th......
__________________
...down to the two Taco's, no more SloYota!
crawler#976 is offline
Old 07-16-2004, 04:26 PM   #8 (permalink)
Guest
jruz's Avatar
I went with Old Man Emu leaf-springs from these guys... http://www.arbusa.com
I'd do it again too.
You will probably want some kind of lift in the front, as 99.9% of replacement springs for the Taco will give you a slight lift in the back.
Jim
jruz is offline
Old 07-16-2004, 04:35 PM   #9 (permalink)
Guest
jruz's Avatar
Oh, and here's some pricing on the OME stuff...
http://www.4by4connection.com/tacoma3.html
(shop around for better pricing, but this isn't too bad)
For my full lift I got:
881 Front Coils
N91C Front Shocks
...and all the other stuff they list to buy. I got it for around $950 (I think...it's been a while).
jruz is offline
Old 07-16-2004, 07:13 PM   #10 (permalink)
mt_goat's Avatar
Sorry to hear that about AOR. I had great service from Alcan, they told me up front at would take 5-6 weeks and the springs were at my door in 4 weeks. They were very helpful everytime I called and almost always answered their phone during business hours. They ask me how much lift I wanted and how much weight I carry in the bed and where. They know Toyota trucks very well. AOR makes a great spring pack (orbit eye bushings) but it is geared more towards hardcore rock crawlers. I could justify the extra cost.
__________________
~Dale~
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Which shocks with TRD front springs/maybe OME rear or PP rear springs Joshs98Runner 95.5-2004 Tacomas & 96-2002 4Runners 9 03-27-2007 11:50 AM
aftermarket springs 881stGenRunner 86-95 Trucks & 4Runners 1 12-17-2006 08:50 PM
Add-A-Leaf on aftermarket springs??? YeloSub7 84-85 Trucks & 4Runners 8 03-06-2006 04:35 AM
Are there any aftermarket springs that don't lift or lower? LSUMatt1514 95.5-2004 Tacomas & 96-2002 4Runners 4 02-01-2005 10:12 AM
aftermarket springs work with spacers? slyang1012 Offroad Tech 3 01-25-2005 12:36 PM
2009 InternetBrands, Inc.
