| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
add a leafs from a chevy?
#2 (permalink) |
Measure the length and width and see how that would work with your springs. Likely they are about 1/8" wider, so might be an issue with the stock u-bolts, if you still run those. But measure and see. Also see how thick they are, there are basically 2 types of AALs, one is long and thin (these are the desirable kind) and the other are short and/or thick, these are not desirable ad they are very stiff and may cause your existing spring leaves to bend over the ends of the stiffer AAL.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
there 2.5 inch wide but there almost as long as the factory leaf spring but there long and thin, they look like they have a good arch to them , the AAL is at my GFs house right now but are leaf AAL pretty much them same for all like universal
#4 (permalink) |
Well, you need to see if the width will fit and on the length, see how that works with the existing leaves, spring clamps, etc. In general, an AAL is somewhat universal, but is typically designed to fit into some existing spring pack, which determines the width, length, thickness and stiffness. If those dimensions happen to fit another spring pack, then you can probably use it.
__________________
