| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
91 toyota TG 5" lift
#2 (permalink) |
I had to take a leaf out of the rear with my 5intg springs to get it level front and rear. i would have your dshaft lenghtened anyway for more travel
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1972 stepside jimmy d44/d70 425hp 1995 green range rover |
#3 (permalink) |
what are your compression and droop measurements?
How long is your shaft and slip? There is your answer.
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#4 (permalink) |
I'd get a longer shaft made anyways...
also, as said above you can take a leaf out, my buddy did that with his front Allpro 5 inchers, took leafs out to lower it. works fine also for the tcase, why would they be stripped, who took it apart? you? for what reason? rebuild? gears? ... throw some red lock tight on em ... take one out at a time, lock tight it, put it back.. so you dont break any seals. truck looks good btw
__________________
1987 Pickup, single cab, 22R, new head, 260 cam TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac. |
#5 (permalink) |
Load up the bed and go 'wheeling - get the springs broken in first.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
| Tags |
| 1995, 4runner, 5, 91, axel, cheap, lift, lifted, perch, pickup, sale, sas, spring, strait, tg, toyota, toyotas |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1987 Toyota Pickup Rock Crawler, 33" Swampers, 4" Lift, Indiana | j_cuz | The Classifieds GraveYard | 0 | 09-10-2008 09:02 AM |
| Need advice on 3" Suspension Lift for '95 Toyota Surf | DaPunch | 86-95 Trucks & 4Runners | 6 | 12-29-2007 06:02 AM |
| Brand new 4" lift springs for straight axle toyota front lift kit | turboyota1 | The Classifieds GraveYard | 5 | 11-09-2007 10:03 PM |
| Downey 2" Lift from Toyota | Darx | 95.5-2004 Tacomas & 96-2002 4Runners | 19 | 10-23-2003 10:02 PM |
