Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Ok I gotta ques I have a 90 toyota with the 22re and was wonderin how it would be to run 33's on stock gearing and a 4in lift!!
| Sponsored Links |
#2 (permalink) |
5spd or auto
5spd it will be slow very slow but torerable. With the auto it will be painfully slow
__________________
-Miles 2006 Camry 1997 4Runner Limited 1995 4Runner SR5 5spd- Fire/Rescue POV WPFD Fire Rescue Company 3 OGFD Service/Rescue Company 2 My ride Working on my 2nd year with yotatech. |
#3 (permalink) |
Its a 5spd yea Im sure those big heavier tires would be hard on my front end and it would harder on my brakes since they have to stop those big tires
#4 (permalink) |
it wont be too bad since you have a 5 spd. I wouldnt worry about it. I have the 3.0/auto and it isnt too bad
__________________
-Brandon 1988 4Runner SR5 4x4 V6 5 Speed Swap SDORI 1.5" BJ Spacers~Downey 26MM TBs~Downey 3" Springs~Downey Shackles~PC ES3000s~PC ES2000 SS~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~33x12.5R15 Yoko Geolander M/Ts~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~3' Firestik II~Marlin Crawler rear~Custom Front~4X Innovations Sliders~WabFab Bikini Kit~Optima Yellow Top~SS IFS Truss. My 4Runner and Other Stuff |
#5 (permalink) | |
Quote:
If you must do the 4" lift either weld the 3 piece bracket type into one piece brackets or just get the one piece bracket type otherwise you'll definitely want to search on my threads pertaining to how to align your truck yourself. Even with the 3.0, 5 speed, and 33's the engine works hard. With the 2.4, you'll have your foot to the floor a lot. The clutch will wear much more quickly as will the engine and drivetrain. Frank
__________________
1994 4runner, 3.0, auto, 5.71's, Truetrac (rear), 33's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos, Marlin rear bumper. www.sdori.com |
#6 (permalink) | |
Quote:
__________________
#7 (permalink) |
I have a V6 with 32's, auto, stock gears, and its dirt slow. I struggle to get on the freeway.
__________________
"off-roading is like crack.... one hit and you just can't stop" |
#8 (permalink) |
I have the 22RE and 5 speed with 33x12.50's. It is ok except for the highway. It struggles on hills at highway sppeds in 5th gear. Around town it isn't to bad. Just know it wasn't a race car before. It wont be one after.
__________________
94 Toyota Truck 4x4 22RE, 5 Speed 175,000 MOD's include High performance Head with bigger valves and cam, LC engineering Header and complete exhaust kit. I have upgraded headlights with the wiring harrness and Hella H4 allweather bulbs. lift shackels in the rear 3 inch BL |
#9 (permalink) | |
i struggle to get on the freeway with a v6 and 30's
__________________
1995 Toyota Avalon: 3.4 Auto with ect power button Quote:
#10 (permalink) |
i'm running a v6 3.slo with 35x12.50x15's with factory 4.88's 5 speed. its not too bad. but definitely not a high performance machine! pretty much in 4th gear on the freeway until i hit about 75mph. even then i can still run it in 4th and the rpms are at about 3100. and yes my gas mileage sucks.....
__________________
1990 toyota 3.0 v6 xtra cab sr5, 5 speed manual hannemann tacoma front end conversion, downey headers, turned down 2 1/2" exhaust Centerforce dual friction clutch 3" body lift 4" suspension lift IFS 4.88 front and rear, lincoln locked 15x10 black rock crawlers w/35x12.50x15 BFG Mud T |
#11 (permalink) |
I had 33's and stock gears with abracket lift and 5spd. SUCKED
Burn clutches, 1st gear has to slip the clutch to get moving. 5th gear is useless unless you are going downhill witha rocket strapped to the cab. don't plan on it. 31's are the practical limit for stock gearing witha 5speed and stock gears...and that isn't even ideal. |
#12 (permalink) |
I have a 90 pickup with 22re manual and stock gears running 32x11.50s it takes me a little while to gain speed but i have no trouble running 75 to 80 on the highway.
__________________
Chris 1990 4WD 22RE Pickup 5-speed 32x11.5 Trailmark A/Ts, 15x10 Mickey Thompson Classic II wheels Total 3 inch lift, 1.5 inch BJ Spacers, Tuff Country 3 inch Add-a-Leafs Custom Twister Exhaust, K&N filter with airbox mod Pioneer 6700 CD deck, Boss 300W Amp, Pioneer 6x9s in custom box Full Size General Lee CB Radio Ashtray Mod, Wilson 2000 Trucker antenna, Bugflector II & ventshades |
#13 (permalink) |
my 85 runner came with 33 mud terrains and it was slow, handled poor and was loud on the fwy and milage sucked. i can only imagine the wear and tear on clutch and brakes. i switched asap to 31 at's and it an awesome day and night diff in all the above. cept it doesn't look as cool.
#14 (permalink) |
I do ok with 32's, 5 speed and 4.56. That said I will put 4.88's in when I go up to 33's next time. There is a noticable acceleration change when you go from stock to 32's. I have learned that the 3.0 loves to rev and 3000 RPM is about the magic spot for shifting. No bogging when the higher gear engages.
__________________
"Turtle" - Green 94 4Runner Looks like one and about as fast JDM altimeter/clinometer, 2002 Sport wheels, 265/75r16 MT/R, , OME stabilizer, BJ Spacers, Cruiser Coils, removed sway bars, rattle can paint for all that peeling clearcoat! Lockright front and rear. |
#15 (permalink) |
OK Ive decided to save and gear my yota with 4:88 gear ratio and run the
33's what do you think is that a good setup |
#16 (permalink) |
I've got a Gen1 Runner 22RE(221K) 5spd w/ 31x10.50's and 4.10's and frankly it sucks. If you're going to run 33's run 4.88's with them. I just drove from Portland out to Central Idaho for a weekend of rafting and I was really trying to kill my engine to get up some of the steeper grades with a moderate ammout of gear in the truck. Add the basket rack and Gorge winds and the truck struggles to keep going 55 some times. Gearing is a great way to save your engine the hassle of being in 3rd to make steep grades.
33's are in my near future, and the 4.88's and a locker are the next purchase. I honestly think that if had the propper 4.56 gears for my 31's now, I wouldn't be so damn anxious to do an engine swap. The 22re is killer and it's a torque'y little motor, but it's small so gearing becomes more imparitive than it is on somehting thaty can just grunt though the mechanical disadvantege.That's juat my.02 Cheers and No Worries Dave
__________________
Project 4Rescue: 89 Gen1 22RE 5spd 4Runner...Marlin DOM rear bumper, OME rear/ BJ spacer front, OME shocks all around. Lucas Pro series HD clutch: DONE!!! BRAND SPANKIN NEW 22RE DONE!!!!! Firefighters: Cause somebody's got to step up and do it... RIP: Charles Edward DelaForest: Born Sept 78 - Murdered May 05 I miss you Brother Last edited by Diesel_Freak : 06-22-2007 at 03:18 PM. |
#17 (permalink) | |
Quote:
4.88's with 5speed is the right gearing for 33's. If you 'wheel the truck at all think about doing lockers while you're in the diffs - the install is essentially identical, so you get the install for "free".
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| no lift and 33's | MAIDEN | 86-95 Trucks & 4Runners | 33 | 09-20-2007 10:32 PM |
| WTB: 4in Lift Kit | MUDN4R | Items Wanted | 0 | 07-15-2007 10:22 AM |
| 90 toyota body lift | npreo1 | Offroad Tech | 3 | 05-03-2007 01:39 PM |
| 33's and a lift | THEYOTAKID | 84-85 Trucks & 4Runners | 5 | 03-14-2007 07:40 PM |
