YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-06-2008, 08:18 AM   #1 (permalink)
ChickN's Avatar
4" with Hi-Steer???
hey guys...im piecing a lift kit for 80 toy and was wondering if i was to throw the 4" lift springs i have along w/ some 33' will i need to do the brake lines, gears, hi steer and all that good stuff at the same time...i was planning on waiting but i just want it up now....and is 33's w/ a 4" lift wierd or should i be running 35's???
ChickN is offline
Sponsored Links
To remove this ad, register today!
Old 06-06-2008, 08:34 AM   #2 (permalink)
4Crawler's Avatar
Can probably make it work stock, brake lines will either need to be extended up front or at least relocate the hard line brackets. The overall package won't work really well until to do the rest of the mods (gears, steering,etc.).
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 06-06-2008, 09:09 AM   #3 (permalink)
4rnr's Avatar
It will work. Of course if you have to do the brake lines do them its cheap/free.
33's are way small, Im running 37's on less than 4" and plan to go to a 38 or 39"
But I do wheel with a guy who went with a 4" lift....then gears...then Hi-steer...then 33''s....duals. I always encourage this type of building because not only does it make you a better driver but it allows you to see and experiance the differences each mod makes. If you want to talk to him he is tonyota on Ih8mud.com
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, custom snorkle, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Electronic shifters by AWshifting, Mcintosh/Dynaudio a/v system.
The build up...http://www.yotatech.com/showthread.php?t=74915
4rnr is offline
Old 06-06-2008, 10:42 PM   #4 (permalink)
ChickN's Avatar
thanks guys...so what would you say i should put on first????
ChickN is offline
Old 06-06-2008, 10:47 PM   #5 (permalink)
4Crawler's Avatar
Well, you need the lift first, otherwise no way to fit the taller tires nor to fit the crossover steering in there (it takes 3"-4" to clear the frame and springs). On my '85, I did lift+tires+gears+lockers in the first round then crossover steering later.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 06-07-2008, 08:08 AM   #6 (permalink)
ChickN's Avatar
what i really want to do is run 35's but i cant afford to do my gears for another month or so which is why i was thinking about just getting 33's...i have the lift springs and the tires on the way. so you think if i can plug out the money for lockers and gears along w/ what i have i can live w/o crossover for a little while(couple months)???
ChickN is offline
Old 06-07-2008, 08:16 AM   #7 (permalink)
4Crawler's Avatar
I ran a few years w/o crossover steering. Depending on the lift, you might need to do a dropped drag link or something to make the steering work OK.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 06-07-2008, 10:02 AM   #8 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
Why not leave the tires for the last? Lift it, gear and lock it and then add some 35's or 37's...
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write...
Blizzard is offline
Old 06-08-2008, 02:33 PM   #9 (permalink)
ChickN's Avatar
i think i might just wait...i went wheelin yesterday it walked all over the stuff my jeep got stuck int or had trouble with...very impressed....oh..and is the 8" rear end a posi...cuz i noticed the rears would be posi quite a bit and i know it doesnt have a locker cuz it doesnt act like it on the road!
ChickN is offline
Old 06-08-2008, 02:42 PM   #10 (permalink)
loacyota's Avatar
Send a message via AIM to loacyota
If the rear hasnt been touched then it is open. You should be able to run 35s with the stock 4.10 gears. wont be an animal but it will work. I just got done doing my cross over steering. havnt taken it out yet, but I wheeled with the old push pull box for a while and it worked, I bent the bar a couple of times, but no big deal. With the crossover you can eventually add hydro assist 2.
loacyota is offline
Old 06-10-2008, 08:16 AM   #11 (permalink)
ChickN's Avatar
what is hydro assist???
ChickN is offline
Old 06-10-2008, 08:26 AM   #12 (permalink)
4Crawler's Avatar
Quote:
Short for hydraulic assist, basically tap into the power steering box for high pressure fluid and feed that into a hydraulic ram attached between the axle housing and the tie rod:
Basically lets you spin the steering wheel with the palm of your hand at any time, moving, stopped, on or off road, in the biggest rocks, makes no difference. More info:
- http://www.4crawler.com/4x4/CheapTri...html#Hydraulic
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 06-10-2008, 10:33 AM   #13 (permalink)
YeloSub7's Avatar
Send a message via AIM to YeloSub7
and if you are talking about a 4" lift from say superlift or procrap, this is a more true 4" lift than what 4rnr has (marlin 4" SAS is more like 5 or 6" lift). You can fit hi-steer with that fine. To fit 35's with that lift, maybe go a little longer shackle. And brake lines will be a must.
__________________
-Jake
1990 4Runner <> 1990 Toyota 4Runner-22RE-5 speed-TG 3" front/4" rear-33's-4.88's-rear LSD-front TruTrac-MC Rear Bumper-TG DOM Sliders!
SAS Build-Up
Old Rigs:
'85 4Runner (RIP)
'95 4Runner (sold)
YeloSub7 is offline
Old 06-15-2008, 08:57 PM   #14 (permalink)
ChickN's Avatar
question......
ChickN is offline
Old 06-15-2008, 09:01 PM   #15 (permalink)
ChickN's Avatar
will 35x12.5r15 bfg mud terrains fit 15x8 wheels ok???? and i got brake lines from the junk yard and am just gunna hook those up to extend them!
ChickN is offline
Old 06-15-2008, 09:26 PM   #16 (permalink)
ocdropzone's Avatar
yes 35x12.50's will work on 15x8's. I am running 33x15's on 15x8's. my guess it that it is probably one of the most common combinations...
I would just recommend you keep on eye on the junkyard brake lines...
__________________
~Robb
'81 Trekker SR5 B4Runner Build
'89 Tercel Project POS Gas Saver
'05 Camry 'Wife's curb destroyer'
'03 Tahoe Family Truckster/Tow Rig
TREKKER Forum
LINK TO ONLINE FACTORY SERVICE MANUALS
All Toyota Website Search Engine
Wheel Responsibly, Don't screw it up for others...
ocdropzone is offline
Old 06-25-2008, 11:14 PM   #17 (permalink)
ChickN's Avatar
so got the back up today....w/ 35's...wow...how bad azz is this!!!! i know you guys cant tell but i got this huge cheesy smile on my face right now...finishing the rest tomorrow. i have a downy 4 inch lift...i believe the front springs are 3 inches but what do you guys think they actually are???
ChickN is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
steer me right Eng1Sqd 03+ 4Runner/GX470, & 05+ Tacomas 2 02-11-2008 05:20 PM
WTB 37-44",toy hi steer in Va 88rnr86up Items Wanted 1 11-01-2007 08:36 AM
80 Pickup Hi-Steer ? corvettelvr73 Pre 84 Trucks 6 07-06-2007 04:19 AM
old school "low steer" crossover arm 94redtoy Items Wanted 0 03-28-2006 02:48 PM
Bump Steer? Albuquerque Jim 95.5-2004 Tacomas & 96-2002 4Runners 0 01-07-2004 07:32 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
