2wd lift kits
Fabtech used to make lift spindles for the front. I heard they are not making them any more (and they're not on the website), that someone else was making them now. You could also go longtravel, like Total Chaos.
In the rear, it's the same as any leaf spring suspension ... axle flip kit to make it spring over, add-a-leaf, new spring pack, shackles, even *gasp* blocks, etc.
Depends on what sort of lift you are looking for, but for a modest lift, you can do ball joint spacers up front:
http://www.4crawler.com/4x4/ForSale/...shtml#2WDor4WD
Something in back:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ14
and something like a body lift to fit taller tires. Had a buddy with an '85 2WD with the above (forget what height body lift) and I think he was running 33x12.50s w/ no problems.
Something in back:
2wd lift kit
I have a 92 base pickup that was running too low, so I bought ball joint spacers from ebay and cranked the torsion bars to get about 2" in front. I added a leaf and a set of springs to the rear to get it up about the same. Since my axle is above the springs, I'll either find an axle flip kit or just fab one myself and weld it to the top of the axle. Luckily, these small trucks are very easy to modify. I also bought some Mits Eclipse 14x5.5 rims to dump the stock wheels, which have a tendency to bend. You can find bushing kits online for about twenty bucks, and replacing the suspension bushings really helped ride and handling.
Lift kits
I just recently purchased a 2 inch lift kit for my 1981 Toyota four-wheel-drive from this website https://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ9.
we really have to read through their webpage good to figure out what you need
I had to send them an email to get help on reading the webpage the person I spoke with was Roger Brown at this email address. r.c.brown@ieee.org
another link https://www.4crawler.com/4x4/ForSale...ft.shtml#NOTES
I I also purchased a 3 inch frame oil springs shocks all hardware from. Corey White Rough Country 800-222-7023 support@roughcountry.com www.roughcountry.com
Hope this helps you and others.
Lift kit
The word oil was not supposed to be in the last reply
it is supposed to rain I purchased a 3 inch frame left springs, Shocks and all the hardware from
https://www.suspension.com/blog/body...spension-lift/
NORCAL SS
02-22-2008 01:18 PM
