| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2wd ball joint spacers
#2 (permalink) |
oh and by the way im getting obsessed 3" lift spindles also but need a little more lift
#3 (permalink) | |
Quote:
![]() http://www.4crawler.com/4x4/ForSale/...n-lineOrdering
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
but without the brace and some light off road use will it crack the uca?
#5 (permalink) |
Generally not, it is usually related to high speed pre-running, jumping or heavy rock crawling type of use.
__________________
#7 (permalink) |
and will they work combined with lift spindles?
#8 (permalink) |
anyone know if bj spacers will work with obsessed 3" lift spindles?
#9 (permalink) |
Might contact Frank @ SDORI (elripster) and ask if he knows.
But if they use the stock upper control arm and ball joint, then they should fit.
__________________
#10 (permalink) |
ok but will it throw off anything and make like th steering or alignment messed up?
#11 (permalink) |
Well if those just have lowered spindles and the rest of the steering knuckle is set up the same as stock, then it should be fine. That is if you can crank up the torsion bars all the way and still align things and steering is OK, then doing the same via the spacers is no different than cranking up the torsion bars.
__________________
| Tags |
| ball, joint, lift, spacers, spindles, toyota |
