| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2nd Gen Adjustable Panhard bar
__________________
1995 4Runner---SAS with goodies |
#2 (permalink) |
Do you have a drop bracket on the panhard bar (can't tell from the picture)?
If not, that is an option: ![]() http://www.4crawler.com/4x4/ForSale/...opInstallation
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
Yep..doesnt help
__________________
#4 (permalink) |
Looks like you either need a longer bracket (bar should be ~horizontal) or find someone that can cut the existing bar and weld in an extension to lengthen it or try something like this:
- http://www.mindspring.com/~jayk3/toyota/torque.htm
__________________
#5 (permalink) |
Thanks Roger..that is kinda what I am looking for.....now I need to find someone to make me one.
__________________
1995 4Runner---SAS with goodies Last edited by Marc P; 12-12-2006 at 09:28 AM. |
#6 (permalink) |
Doesn't someone make an axle side lift bracket? I thought I remember seeing folks that used both a drop at the frame and a lift at the axle to get the bar level....
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#7 (permalink) |
marc you have cruiser coils correct? i have the OME 901 coils that dont lift it as much and i do not have a drop bracket, even though i dont have 4" of lift would that bracket work for me? as i sit now if i flex the rear at all the driveshaft digs into the gas tank skid plate and makes horrednious noises. sorry if this is a highjacker.
__________________
1993 4runner: ARB air locker rear. aisin manual hubs. SDORI ball joint spacers, OME 901 coils, Sonoran Steel IFS truss, 33x10.5 BFG AT's, hacked into the dash clinometer, marlin crawler sliders, custom armorology rear bumper, and a lot of custom dents. -Byron |
#8 (permalink) |
It will help a little with the gas tank clearance, but it may shift the axle to the side like I am trying to deal with.
__________________
#9 (permalink) | |
Quote:
http://allprooffroad.com/index.php?o...sk=view&id=122
__________________
#10 (permalink) |
I think everybody here has seen my views on panhard brackets and axle position, so I won't go into that.
Marc, your only solution is to lengthen the panhard.
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! Last edited by Robinhood150; 12-12-2006 at 03:41 PM. |
#11 (permalink) |
That is one expensive piece of metal....
__________________
#12 (permalink) |
I would agree, that is one expesive piece of metal. You could make your own for less then a fraction of the cost. And you would be able to get the length/height just right.
#13 (permalink) |
Staff
I'd sell what you already have and switch to leaf springs... http://www.yotatech.com/showpost.php...8&postcount=15
#14 (permalink) | |
Quote:
__________________
http://www.trek-planner.com 1992 Toyota 4Runner|3.slow|5spd, SR5|Flowmaster 40|SAS 5" f/r|Detroit rear|ARB front|5.29's|roof rack|FLX 165|35x12.5r15 BFG MT|CB|ISR|Alarm|BentUp Sliders|C02|30 spline longs |
#15 (permalink) |
I agree about switching to leaves too, but I need to plan it and get more $$$
For now I will have a buddy make my panhard bar adjustable....does anyone have pics of how it should look on a 2nd gen?? all I see is 3rd gens..
__________________
#16 (permalink) |
Marc, I have a custom extended panhard with a heim and stock joint at the axle. Combined with the panhard drop and 5009 shocks, it was the bee's knees.
Somehow my other links disappeared, but that would be a caddy set up. Let me know if you want it. Need to get some cash out of it, not too much.
__________________
Ease on down the road. |
#17 (permalink) | |
Quote:
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler Auto – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35's, FR&RR E-Lockers and too many things more to write... |
#18 (permalink) |
One more thing to add...I've got leaves in the back and my driveshaft still hits the tanks. Sheared off one of my balancing weights too. But my tank is a little bashed in that area so it might be a little wider than a normal tank.
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
#19 (permalink) | |
Quote:
__________________
#20 (permalink) |
I'm pretty sure you don't have more of an angle on your panhard bar than I do with the Downey coils I bought from you and finally installed. Granted, I don't do any wheeling, so I never notice any interference with my gastank or something like that. I haven't even noticed my rear diff being off center, but now I want to look and see if they are.
__________________
94 4runner SR5, V6 3VZE, 5 speed Completely rebuilt engine with Toyota parts at 147k miles Downey Coils, Aisin manual hubs, Cowl Louver mod, Hella 500 fog lights Yeah, I know, not many cool mods here Last edited by runethechamp; 12-13-2006 at 09:45 AM. |
#21 (permalink) |
Mark, I got the All Pro lift bracket on the driver side and return the passenger side to stock location. It's not parallel with the axle but it seems to keep my rear axle centered.
This is not the best pic but atleast it shows the AP bracket.
__________________
http://www.angelfire.com/ca6/954runner GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1. ..."But officer, that was not an illegal turn, it was just an undocumented turn." |
#22 (permalink) |
runethechamp, this is what happens when you've some more drop than the stock shocks...
![]() I've OME 901's so I don't have 4'' of lift... Driving I don't notice difference but when I disconnect the anti-swaybar... Hehehehe
__________________
#23 (permalink) |
Hey Mark,
with 4" pan hard bracket I got, I'm actually too far on the driver side. I took pics of it with a pen to demo the difference in the distant of the tires to the frame. I'll post that soon. It seems there should be something between 3" and 4"...I think my truck leans at the passenger rear side too. At this point, I'm not sure what the problem is cause I've already swap the rear coil..lft/rt.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3rd gen Adjustable Trac/PanHard Bar | ROOFGOOF | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 10-13-2006 07:36 AM |
| 2nd gen trac bar/ panhard bar removal | Y2Krunner | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 08-04-2005 02:05 PM |
| Lift done w/ adjustable panhard bar | Praufet | The Fab Shop | 12 | 05-15-2005 02:22 PM |
