| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2002 4runner wants 2wd to 4wd conversion
#2 (permalink) |
A lot. You'd need a transmission with transfer case, driveshafts, front diff, axle shafts, and all the associated electronics.
__________________
2001 4Runner 4.30 ratio 1999 e-locked rear axle and front diff; OME881/N91S front; OME891/N86 rear; Tundra brake swap; 1" 4Crawler body lift; 63" 4Crawler SliderZ; TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line; 265/75R16 Nitto TGs or 255/85R16 Truxs MTs; Cobra 75 WX ST cb; Alinco DR635 VHF/UHF ham radio; ham call sign license plates - VE7 EGC |
#3 (permalink) |
Why not buy a beater 4x4 to use for fishing/hunting trips? Would be alot cheaper.
#4 (permalink) |
A member on here did a similar swap a few years ago. I'm sure he is happy with the conversion, but probably not cost effective...
__________________
Mostly Stock 90 4Runner SR5 V6 Auto w/ 33" Durango MT's (bent lower valance removed), bush bar w/ 55w Baja Offroad Lights, Custom fit 1st. gen rollbar (used to mount Hi-Lift and fire extinguisher), extended diff breathers, (Comming soon rear spool and 2" body lift..) My very slow buildup on Sontt.com - currently building. http://www.sontt.com/forum/viewtopic...&t=109&start=0 |
#5 (permalink) |
__________________
#6 (permalink) |
Unless you have extensive modifications to your current rig, you're better off trading in and just getting a 4WD.
Other option is to put a locker in your 2WD. 2WD + sand = lots of speed and low tire pressures
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#7 (permalink) |
Thanks alot
Thanks alot everyone for all your info and time.
One of the sole reasons why i didn't want to buy a new rig is because i had alot of work done to my truck already. I really appreciate yall helpin me! |
#8 (permalink) |
also check out the 2wd to4wd kit from www.inchwormgear.com
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1972 stepside jimmy d44/d70 425hp 1995 green range rover |
| Tags |
| 2002, 2wd, 4runner, 4wd, conversion, runner |
