1997 4 Runner Tire Size Question with 3 inch lift!!!!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-10-2006, 10:17 AM   #1 (permalink)
ok here is what I have
1997 4 Runner 891s in the rear
Rev Tek in the front with the top out spacer, also have the diff drop
I am running the factory 16 X 7 alloy wheels
Can I fit 285 75 16s? I do not mind doing some minor trimming in the front i.e. front bumper, pinch weld etc, I do not have running boards and do have an offroad type rear bumper which is about 2 inches further away from the rear of the rear tires than the stock one
I hear it would be best to do a 1 inch body lift, but I would rather not, as I have another project I am working on and do not want to divert my attention from it
Please advise, I think I can live with minor rubbing, and do not mind cutting, trimming as necessary
the truck is mainly street driven but does see regular duty on the beach, often in wet, deep sand.
Thanks, Tim
__________________
305k MILES! 97 4Runner Khumo Road Venture MT's 285 75 16's LC wheels,Desert Dune,moonroof,safari rack,kc daylighters,3.4 Ltr. 5 spd,410s detroit ez locker, OME 891's, KYB shocks3 - 3.25 lift, Tokico,Taco springs,3 in lift in front Rev Tek spacers/top out 4Crawler diff drop, 1 in BL, 4 Runner altimeter, 2.5 in Flowmaster,high flow cat, mandrel steel air intake conical K & N. MSD DIS4,CB with 7 channel wave/weather report,4 foot firestick,Pioneer CD,30 gig IPOD.
www.sfaboston.com
BOSTON4RUNNER is offline
Old 04-10-2006, 10:19 AM   #2 (permalink)
FilthyRich's Avatar
yes you can.
16x8 with 4.5" bs would be better...Oh and I have three LC wheels for sale too
__________________
Eric
88 4runner
Quote:
Originally Posted by AxleIke
"Just wheel what you got until it doesn't cut it anymore".
FilthyRich is offline
Old 04-10-2006, 10:39 AM   #3 (permalink)
so think I will need to grind some stuff down?
I mainly drive on the street but will do beach driving
I wont be doing any heavy rock climbing etc, crawling over downed trees or the like
__________________
www.sfaboston.com
Old 04-10-2006, 10:43 AM   #4 (permalink)
ebelen1's Avatar
Quote:
Originally Posted by FilthyRich
yes you can.
I thought I read here that the stock 16x7 wheels w/ 285's would rub the a-arm. Isn't that why others have gone to wheels like the LC ones because the offset works w/ the a-arms? I could be wrong but I thought this was the situation.
__________________
____________
Edwin
1999 SR5 4unner
ebelen1 is offline
Old 04-10-2006, 10:48 AM   #5 (permalink)
FilthyRich's Avatar
it will rub a little, but for his intended use, it will be ok--not perfect, but ok.
LC wheels are ideal b/c of the size
__________________
Eric
88 4runner
Old 04-10-2006, 12:57 PM   #6 (permalink)
what year landcruiser wheels are the trick?
__________________
www.sfaboston.com
Old 04-10-2006, 01:03 PM   #7 (permalink)
FilthyRich's Avatar
93-97.
http://yotatech.com/showthread.php?t=82319
__________________
Eric
88 4runner
Old 04-10-2006, 07:41 PM   #8 (permalink)
terryjmatthew's Avatar
FWIW, I mounted a set of 285/75R16 Revos on my stock wheels and did not have any rubbing on the UCA's. It all depends on the actual dimensions of the tire.
__________________
-Matthew
http://www.yotatech.com/f79/terryjma...rofile-103826/
TLCA # 17870
terryjmatthew is offline
Old 04-10-2006, 07:46 PM   #9 (permalink)
thanks for the input!
__________________
www.sfaboston.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Tire Size Question (15 inch wheels) Matt 95.5-2004 Tacomas & 96-2002 4Runners 12 09-02-2009 05:20 PM
1997 TOYOTA 4 RUNNER ALUMINUM 16 inch WHEELS WITH 31 INCH ALL TERRAINS BOSTON4RUNNER The Classifieds GraveYard 1 04-11-2008 12:27 PM
Tire Size and Gear question with no lift Twisted Intentions 84-85 Trucks & 4Runners 8 03-02-2006 10:41 AM
Biggest Tire With 3 inch body lift? Dual Exhaust? Tomh4x4 95.5-2004 Tacomas & 96-2002 4Runners 19 01-25-2004 11:54 AM
2009 InternetBrands, Inc.
