1990 4runner upper control arm links - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-02-2009, 12:57 PM   #1 (permalink)
i have a 4" lifted 4runner coil springs in rear. i need to make adjustable upper links. The lift kit gave me relocation brackets to raise the upper links. should i not use the brackets? how long should the tubing be before the end links are in
1990IFS is offline
Old 11-02-2009, 07:11 PM   #2 (permalink)
tc
tc's Avatar
Huh? Raising the axle end of the uppers is going to change the way the suspension works pretty dramatically. Got any pics of these brackets? How much does it raise them?
Why do you think you need to make adjustable links? (ie - what is wrong) Admittedly, the uppers are a weak point in the stock design IMHO.
Here's the link to my reworking of the rear 4 link:
http://www.yotatech.com/f116/tc-s-2n...thread-153382/
What is your fabrication ability? Can you weld well enough to trust your life on it?
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is online now
Old 11-02-2009, 09:20 PM   #3 (permalink)
i need to tilt the axle back a little because of driveline vibration
1990IFS is offline
Old 11-02-2009, 09:22 PM   #4 (permalink)
allpro offroad used to sell what i am looking for but they have discontinued them
1990IFS is offline
Old 11-03-2009, 08:33 AM   #5 (permalink)
4rnr's Avatar
your coils/coil-buckets wont be happy, and you may bind your shocks in more ways than one. You may also bind the Panhard. Basically...bad idea.
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system.
The build up...http://www.yotatech.com/showthread.php?t=74915
4rnr is offline
Old 11-03-2009, 08:36 PM   #6 (permalink)
tc
tc's Avatar
My guess is that you actually need to rotate it DOWN (ie - need longer uppers). The flanges at the tcase and pinion ends need to be EXACTLY parallel so that the vibes induced by the ujoint on one end are cancelled by the one on the other end.
The other option is to go to a double cardan driveshaft and point the diff directly towards the tcase output, but as 4rnr said, this will cause problems.
__________________
tc is online now
Old 11-04-2009, 08:02 AM   #7 (permalink)
4rnr's Avatar
Shorter uppers will rotate the axle "down".
__________________
poop
4rnr is offline
Old 11-04-2009, 03:06 PM   #8 (permalink)
tc
tc's Avatar
Oops - yes, you are correct.
__________________
tc is online now
Old 11-04-2009, 08:52 PM   #9 (permalink)
4rnr's Avatar
i knew what you meant
__________________
poop
4rnr is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
